Need north of the border Help
Lee Schierer - McKean, PA
>I purchased my Delta 14" bandsaw (Model 28-274C serial # 011848Q2001C)) in Canada in 2001. Last night while using the saw, the power switch failed in the on position. The only way to turn off the saw was to pull the plug which wasn't on my side of the saw and I had a piece hung up.
Anyway I tried the Delta Internet site and they don't list my saw model so I called Delta this morning and they don't have my saw model in their system. One lady finally directed me to a Vancouver number where perhaps they could help but she wasn't sure. When I asked about some place on this side of the country her reply was she had no idea where Vancouver was. I suggested that she spend a little time updating her geography knowledge.
Would one of your guys north of the border be able to check on the price and availability of a power switch (p/n 1234945) from a local supplier somewhere on this side of Canada. I would appreciate a lead on where to get a new switch. Either post the information here or send me an email.
Thanks,
Lee
Re: Need north of the border Help
99 cent solution
>For a temporary solution, you can get a 99 cent light switch and wire it into the box. Oops, you'll have to get a 29 cent switch plate cover to go with that.
Probably not the safest, but better than unplugging it to turn it off ;)
I really doubt you need to get the part from Canada. The Delta 14" saw has been made for 50 years and parts like the switch only change every decade or so. You should be able to get a switch from any similar Delta 14" bandsaw. In fact, just look up the model nubmer without that extra "C" at the end. I think the C only designated that it was for sale in Canada.
ANd you can get an aftermarket switch for less than a Delta switch that would be safer than the 99 cent solution I mentioned first.
Happy Woodworkig!
Re: 99 cent solution
>Apparently the switch arrangement is peculiar to Canadian versions as the switch part number did not work for the guy at Delta either. It is a .75" x 1.375 panel mounted switch STDP toggle type switch rated at 20A/125V. It fits under a shield that also functions as an E-stop button. The switch itself was made in China (KEDU HY26) but is pretty cheaply made.
Lee
Re: Take the switch to....
Kneale Brownson awaiting snow in N. MI
>An electric repair shop. They probably can find you a replacement.
>I bought a new switch off myPerformax. Turns out the old one was full of sawdust and that kept it from making contact. If I had known that, I probably would have figured out how to bow it out. I managed to take it apart (after I got the new switch) and cleaned it out, but was never able to reassemble it. (apparently they have special training or superior dexterity in the Chinese factories.)
Anyway, the new switch has a red and yellow toggle or "flap" on it and would work as an E switch. I have seen identical looking switches advertised, but for the life of me can't remember whether it was Grizzly or JET. Seems to me it was pretty cheap, like less than ten bucks. May have been Harbor Freight. Somebody posted it within the last two months. Any switch rated for enough amps would work. If the saw is running on 120 you need a SPST, for 240 you need DPST, in any configuration you can make work with your mounting hardware.
Oh, okay.....
>"...STDP toggle type switch rated at 20A/125V..."
Oh, okay... so you'll have to get a $1.99 switch at HomeDepot instead of the $0.99 one ;)
Depending on the price of the OEM, there are plenty of other good switches you can use. I know a household light switch will work, but doesn't have any sort of e-stop or safety stop or lock. But there are several aftermarket switches, with red hinged covers for emergency stops, etc that are available from various sources. WoodCraft, Rockler, etc.
Happy Woodworking!
So put it an a metal box
Gary Camp, Bend, Oregon
>I used a light switch in a surface mount 2 X 4 metal box screwed to a roud pice of plywood for my garage sale "sohp vac" for years. It out lasted the motor. Maybe sucking the water out of a leaky sprinkler valve box / hole wasn't such a good idea after all. Oh well I got 10 years out after the Drywaller that sold it thought it was worn out.
glc
Jim Shaver - Oakville, Ontario
>Hey Lee,
I'll dig around for you and see what I can find out, give me a few days.
Take care,
Jim
GerryinSurrey formerly Agassiz previously Halfmoon
>Hi Lee
I called our local tool outlet/tool repair shop and they directed me to the Black and Decker/Delta/DeWalt/etc etc depot here in the Vancouver area. The young feller at the parts depot has two of the switches you mentioned, they are $33 plus change each and he doesn't ship to the US. I don't know if you want to go for a $33 switch, I sure wouldn't but if you want it and can't get it elsewhere I could go pick it up monday and ship it to you. He also gave me the changeup part number which is 905224. You may have some success hitting up a parts depot a little closer to your home. Oh, I think the reason for the heavy price tag on the switch is that it is a complete emergency stop type switch with all the bells and whistles. They don't have just the bare unadorned switch available. Let me know how you make out, we know now where there are at least two of the elusive little buggers.
Gerry, digging out from about 4" of umported global warming. (Al sent it, didn't he?)
