How to Finish Frame and Panel Doors
Joe Doker
>I'll be making some frame and panel cabinet doors out of cypress. The panels will be solid 1/4" material so I know they need to float in the frame. How do you finish so that if the panels shrink, you don't have unfinished aras showing near the edges? I will be spraying with a Vinyl Sealer followed by CAB Acrylic Lacquer.
Here's what I am thinking: Spray the entire panel with sealer before assembly. After assembly, spray the frames with sealer and don't worry about overspray onto the panels. Then sand and apply Lacquer to the entire door. Is this the right way? Is there a better way?
Thanks
Re: How to Finish Frame and Panel Doors
Dan Donaldson
>If you want to be sure not to get edges showing, completely prefinish the panel before you put it in.
>I agree with Dan: pre-finish the panels, but reconsider the vinyl. It's unnecessary and requires top coating sooner rather than later. I often use CAB acrylic (Sherwin Willians) and it self-seals very well.
Make sure the panel wood is fully relaxed. I once made a cypress paneled door that twisted the frame apart.
Clint
Jim Dillon
>Joe,
Like Dan and Clint, I am also a big fan of prefinishing the panel. It really makes the whole door neater looking IMHO and avoids any unfinished wood showing during seasonal changes. I sometimes pin each end with a 1/8 in dowel. You might want to consider using those small rubber "space balls" around the panel edge to stop any panel vibration when you shut the door. If you do, plan ahead and make sure the stile and rail grooves are deep enough (DAMHIKT). Good luck with the door.
Jim
>Fix the panel in place horizontally with escutcheon pins from the back center of the rails into the panel.
Clint
Jim Dillon
>Clint,
Sounds like a very attractive alternative to a small dowel. I've used the brass escutcheon pins (Lee Valley) for fastening the small strips of wood used to hold the glass in glass paneled doors and like them a lot. Never thought of using them for holding a wooden panel in place. Thanks for the tip!
Jim
>Jim, another approach is to use bamboo skewers from the supermarket to pin the panels in place. I've also used them to hold dovetail joints, through the exposed face of the tails into their ways. They are an attractive accent in the finished joint, and resist any tendency for the joint to loosen with seasonal movement or starved glue failure (or sloppy fit).
Clint
Joe Doker
>Thanks all, for the advice. Since I did the posting, I had a quick and dirty piece I needed to finish quickly and skipped the vinyl sealer and the CAB Acrylic Lacquer did finish quite well without it. Good idea.
Joe
