DC as fumes ventilator question?
>I have a Delta Dust Collector with a bag in an outside closet. It does not return its air to the shop. I was wondering about using it to ventilate lacquer fumes. Made a bunch of small items I am spraying with Deft spray cans of gloss. I can see the possibility of a spark setting off a vapor explosion, but since it is running in "free air" I doubt there would be any sparks. Any other reason I should not do this. Will the lacquer clog the bag? ETC.
Re: DC as fumes ventilator question?
>I can't talk about lacquer but I use it to get rid of the fumes from CA glue and it works great. I would be concerned somewhat about the overspray from lacquer getting in the pipes.
>You probably won't have a high enough vapor concentration to support combustion with the amount of CFM that you are moving (I am assuming over 700 CFM). I would worry about clumping in your bag eventually. So this means you'd have to actually vacuum out your bag rather than shake it out.
Most bags become more efficient air cleaners due to dust caking - yours would become more efficient faster :).
Jesper, Denmark
No problem...........
Jesper, Denmark
>Assuming your DC is pumping something like 1000 cfm, you would have to spray more than 50 lbs/hr to get to the LEL, so a few cans while you run the DC will not getinto the explosive range.
Industrial paint systems put a lot more VOC into the air than you can ossibly do at hopme. They typically operate at about 1 or 2% of the LEL.
No thanks, I already have a job :-)
Denis Ch�nard, Orl�ans, Ont.
