Re: Hmm. A possibility for you...
Brian Green
>First, a couple of assumptions. 2lb white shellac is a light clear as opposed to amber or seedlac and not the white pigmented variety and the gel stain is the color your shooting for. Often times the washcoat of shellac is used to prevent blochyness, esp. in cherry, maple and of course birch..so is using a gel stain.
I've never seen a 2lb cut used for a washcoat to prevent blotching, often times finishers use a 1lb cut or even 1/2 of that, similar technique as using glue size on endgrain. After that you lightly sand to allow the top fibers to soak up the stain. You've sealed the wood and the gel stain really doesn't penetrate well to begin with. As Ellis said, I'd use a solvent to wipe off the gel stain (stain directions will tell you what you need for clean up), it should redesolve and take most of the gel stain off. Now you have a couple of options:
1. Probably the easiesy is to make a toner with trans tints and shellac, or possibly use your gel stain in shellac (if it will dissolve). This will allow you to add uniform color in layers, don't try and get it in one coat (your toner is too strong). Not sure how your putting on the finish (french polish vs spraying vs brush) so this may take 4-5 coats. Then top coat with the clear shellac or finish of choice.
2. Sand back to bare wood and start again....yuk
of course as you already said a small sample board would have shown you if this is what you wanted...trying to do a finish on a project without this step well, been there, done that, have the tee-shirt.
Good luck, I'm sure that you can salvage your project, it'll just take alittle longer.
BG
