ADVERTISE HERE - FREE TRIAL
It's cold - so how do you cope with finishing?
>I've got a piece to complete. It is in my heated basement shop. I've been waiting until the outside temperature gets up to 60 degrees so I can put the exhaust fan in the window. But that isn't until mid or late afternoon (if at all). I don't like having the solvent smell in the house (or rather SWMBO doesn't).
I am wiping on multiple coats of finish (Tung oil/polyurethane/mineral spirits).
Re: It's cold - so how do you cope with finishing?
>One of the reasons I changed to waterBORNE finishes, is thatI can spray or apply them by hand regardless of the outside temps. Can't spray shellac or lacquer, but shellac barrier coats I can pad on easily. Plus I can get 3-4 coats a day on as opposed to 1 to 2 for oil/solvent finishes.
mm
Re: Don't some of them have solvents?
>Such as small percentages of methyl pyrollidone, glycol ethers, methyl carbitol, trimethyl benzene and possibly a bit of naphta?
I tried one of the Polycryl waterborne finishes and it had less odor (and less solvents) - but it still had an odor.
Sure
>But the amounts are pretty small. If your goal is to remove all solvents from your shop/house/work area, then you're stuck between waiting for warm weather and having your furnace contribute directly to global warming.
mm
Cold finishing is no problem
Lee Schierer - McKean, PA
>I use Deft Clear Wood Finish as my primary finish. A number of years ago I had the same question and contaced Deft. They said I could apply the finish and it would cure at any temperature I could stand to work in. It would still cure and be fully functional even at freezing temperatures. It is a lacquer based finish and the solvent is lacquer thinner so it needs to be used in a well ventilated space. I finish in an unheated garage and have applied the finish at 20 degrees F. It takes several hours to overnight to dry and it takes several days after the last coat for the finish to set up really hard but other wise it works the same as in warm weather.
Lee
Re: LOL...
>I just wait for a warm spell - we keep the house at 60 degrees during the day. Of course that means the cats will lay on the heat vents when they come on.
Re: General Finishes gel *LINK*
pecker
>I recently used General Finishes Satin Gel wipe on varnish. Besides being great to work with, it actually had a pleasant smell. And even that disappeared quickly, as the stuff was substantially dry within an hour.
http://www.rockler.com/product.cfm?page=11243
