REAL MILK PAINT
grizzly 8 inch joiner
WRF
>This is like half the price of the jet /delta powermatics etc.
Is it a case of you get what you pay for or is this a good tool?
Not looking for nasa stuff just want to get my stock straight and flat and square.
Any body own or use this tool? Comments?
Re: grizzly 8 inch joiner
Howard Norman
>I purchased the Grizzly G0490 right after it came out a couple of years ago. There were shipping problems on the first shipment which included my unit. Grizzly took care of the problem and changed their shipping procedures and I haven't heard of any problems since. It is a good well built machine in my opinion.
Howard
Wayne in Atlanta
>I have a 6 inch Grizzly jointer. It's tables are as flat as my 40" straightedge across both tables. I have 14" bandsaw from Grizzly too, and the wheels were perfectly coplanar right out of the box.
I've been thinking of getting a bigger jointer, and most likely I'll buy another Grizzly. And if I move up from my 12.5" Delta planer it will also most likely be a Grizzly too.
Wayne
>I have a 1021 planer that I have had for 16 years and haven't had any problems. I also have owned an 8" jointer for the same time and haven't had any problem either. They arn't as finished on the outside as the higher priced but I like them better than the Delta which I owned before these.
Ken Krawford
>I bought the 8" G500 several years ago and love it. (especially the 72" bed). It has done everything I need. If I was buying another one, I would spring for the spiral head cutter though.
Re: Happy man here
Brian in Brighton
>I got the G0490 and bought the Byrd insert Shelix head.
I like it a lot, but do not have much time on it yet.
Brian in Brighton
Size matters
JohnM in Mid Mich
>Get the biggest d*#%.ed jointer you can afford. Get the most powerful d*#%.ed motor you can get. I have had a 12" jointer for the last couple of years and it is hard to imagine how I ever finished a project in the past without it!
J.
Mike Schwing from Maryland
>I have recently purchased the G0490/parallelogram jointer and am thrilled with it! It was a good jointer with the standard/straight knives, but I installed the Byrd Shelix cutterhead and it is now a dream machine. It now machines the gnarliest and most figured of woods to a silky smooth finish with zero tearout. Also, the beds were perfectly aligned from the factory. I'd buy it again. The only negative, at all, is that there is a spot in the rear behind the fence that shavings blow through, but all of the other waste goes right into the dust port.
WRF
>thnx all for responses, sound like very positive recomendations
Craig Daymon
>Sorry for busting in, but I was just looking at the G0490 with the spiral cutterhead. I imagine it's not quite the Byrd head, but probably produces a good cut.
Anyway Mike, my big concern is whether I can get it down the basement. I have one of those stupid 180 degree corners going into the basement that the builders like so much now and I was told the Powermatic parallelogram 8" jointer wouldn't make the corner. Do you think the Grizzly could? (The PM didn't have the option for the spiral head either.)
Thanks,
Craig
