Partial Gloat, Partial Guestion
Ron Hildreth
>Good Morning, all,
Yesterday I finally made the trip to Cedar Rapids, sorta on a spur of the moment, and picked up my new Rikon band saw. I'm just in the process of getting it set up, and it occurred to me that this band saw will be the first one I've owned that utilizes roller style blade guides rather than the solid type (cool blocks). The owners manual is a little vague on the right way to adjust them. How do you guys set your's up? Is a feeler gauge best to use, or a dollar bill or do you just allow them to barely touch the sides of the blades?
Thanks!
Ron in Iowa
Re: Partial Gloat, Partial Guestion
>I used a bright light behind the guides and adjusted so I could just see a sliver of light. The dollar bill or feeler gauges would also work. I used the light because I only have two hands :) - and I figured I could hold and adjust my guides with one hand and use the "wrench" with the other a little easier.
Re: Partial Gloat, Partial Question
>Congratulations on the new saw. Hope this does not turn out to be your best day with it. May it exceed your expectations for years to come.
I have the Delta with the riser block and bought the Band Roller guides from Iturra. These are tiny bearings mounted in aluminum blocks that fit where the cool blocks used to go. I am somewhat unscientific about setting mine. I just bring them up close and leave the least amount of daylight I can. Seems to work. (Be warned, I have a love/hate relationship with the saw. There are days it is good I don't keep a gun in the shop. One of us would have been gunned down.)
A word of caution. Keep and eye on the bearings below the table. I cut green turning blanks and find the long stringy shavings pack up in the bearings and their holders. Have to blow them out. (Air hose, not shotgun.)
Pat Evans
>I use a piece of masking tape around my blade. Stays in place while I adjust the rollers and comes off easily.
Sean Troy
>Great idea about the masking tape. I'll have to try that.
McKay Sleight
>I hope that you like yours better than I do. I have two lagunas and a 36" yates/american. I really do not like the Rikon.
If your alignment is "dead on", the bearing can
Art Silva
>ride on the blade without any problems. Be advised that blades less than 1/4" wide cannot be used with the rollers. You have to use Cool Blocks, or Ceramic blocks. There are some 1/4" blades with few TPI and aggressive pitch that cannot be used either, because the bearings cannot be retracted far enough. Good luck.
Re: Partial Gloat, Partial Answer *LINK*
>On my Carters [partial gloat] I set them to a piece of paper gap but . . .
I do so with the blade properly tensioned. Therefore, before you set your guides, back them off from the blade and run a flutter test to find the right tension setting for your blade. The flutter test is explained on the Suffolk Timber Wolf web site at the link.
Then, with the blade properly set, adjust your guides so that the side rollers and thrust bearing are all one sheet away with the side rollers set back so that the teeth-sets will stay clear of the wheels when the blade makes contact with the thrust bearing. You also want to make sure that the thrust bearing set screw is well tightened. When that's all done, back your tension off a given number of turns (I use 8) to avoid stretching your blade and spotting your tires when not cutting. Retension your saw by cranking the same number of turns on the tensioner.
mm
Suffolk
Ron Hildreth
>Thanks, Guys!
One of the reasons I bought this Rikon was it came with a quick release blade tensioner. Several good ideas, like the tape for adjusting the rollers that I especially liked. Thanks Mark for the Suffolk link. That will be a big help!
Ron in Iowa
