>Well I have one more trip this year then I am done until Feb 2008!!! YIIIPPPEEE. Anyway the LOML and I have decide to tackle the stair case. Right now I have carpet on it and want that to go away fast. I am guessing construction lumber for treads. I want to change them over to Oak treads.
What is the required thickness of stair treads? My question can I use 3/4 Oak ply and band the front with soild Oak or would these be to thin? One last one if I can not use the ply then can I edge glue the boards or do I have to find wide boards?
You could take the easy way out and buy the already milled, bull-nosed oak stair treads at Hartville Hardware. They're either 5/4 or 6/4 thick - I forget which.
>I don't think you want to use a ply with fake bullnose on an exposed wood stairway. First, depending upon its width and underpinning, the 3/4 ply would be quite a bit less strong than a full-inch oak board, which is what I think stair treads are. Second, wear on the thin oak veneer wouldn't make it very durable.
>When I did my stairs, I used stair nose from the orange box and used 3/4'" oak for the treads. They sold treads in a pack of 3 but that was too expensive for me. Solid oak t&g'd worked and looked nicer. My 2�.
>As far as I know there are no Code requirements for the thickness of stair treads. Locally, almost all of them are made from full 1" (finished dimension) Oak or Pine. The trades are usually glued up stock, dressed with a bull nose and are available at the Borgs and other lumber yards. Some are made of framing lumber like 2 x 12's and are 1 1/2" thick. Those are often covered with carpet, but the 1" bullnose pine ones are often left exposed as basement or attic stairs.
There are Code requirements on the rise and run. One requirement that might affect you is that no riser can say more than 3/8" from any other. This is the "tricky" part of building stairs for many people. If you were starting from scratch and you cut the stringers or horses so that the all the rises were 7" and then you install the treads, the bottom stair will be 8" and the top one will be 6", assuming the floor covering there was already in place. All the middle ones will still be 7" because you add the same amount to each step. On a flight of three steps this ends up from the top and a 6,7,8 and a fall.
In your case, if you pull out 1 1/2" stock and replace it with 1" stock and all your risers were 7" before, now the bottom one will be 6 1/2 and the top one will be 7 1/2" and you will have more than the 3/8" variation allowed by Code. I'm not suggesting that you should buy a building permit and get yourself busted by the code guy, but what I am pointing out is that people are very sensitive to the rise and run and poorly laid out stairs are a tripping hazard. And the requirements of good design might be tighter than you thought. This also gives you a chance to correct any defects lift by the builder.
You also want an over hang or projection of the bull nose over or beyond the riser. It should project an 1" to 1 1/2". This makes the stairs much more pleasant to walk. Your heal does not hit the riser on the way down.
I did an inspection on a house that had OSB for both treads and risers with carpet over them. The way they found out was the father plunged through one of the steps. They were crap. Don't do that.
>I have built a few stair cases over the years. People always ask m;e if it is hard to build stairs, I answer, no, it is not hard to build them but it is hard to build them right so that all of the risers are the same and you end up with the right amount of rise over run, etc and it feels right when you walk on them. The best way I found is to lay a pattern out on a stringer while it is on saw horses, cut the top and the bottom to what you calculate is right and then set it up in the opening to check it before you go to all of the work of cutting out the risers, etc. just my two cents worht. Jared
>My stairs are shown in the PIC below. The treads are solid oak, open on one side. The side of the treads are banded with the same bullnose as the front of the treads. My question relates to how that side banding is attached. How do they attach this so the tread doesn't split or the edge band joint doesn't split? I assume there is allowance for seasonal expansion and contraction of the tread, but I can't figure how. I didn't watch them being built. Anybody know how this is generally done?
>...were just butt joints air-nailed on. There's enough give in the wire nails to allow for movement. I'm sure there are other options, depending on the price point.
