Have a question? Ask Woody!
Really OT: tooth brighter
Carol - now in NC Nebraska
>No, not saw teeth. Human teeth. Dingy runs in my family and I'd like to brighten my smile.
And suggestions?
Re: Really OT: tooth brighter
That depends.... long
Steven Kubien
>Do you have any 'white' fillings on any of your front teeth (front 4 either side of centre on top and bottom)? If you answer yes, any whitening agent will act on your natural teeth but not on the filling. That means get the filling re-done after the whitening procedure to match the new shade.
Another approach would be veneers. These are very thin sheets of porcelain or other ceramic material which are bonded to your teeth, after they have be carved down a bit. These would be permanent and at the same time you can adjust your smile a wee bit (fix that slightly crooked one or close the gap between others. You know what I mean.) If I was to go with veneers I would find a dentist using the Cerec technology. It's a CAD/CIM machine which is out of this world.
Other than that, stay away from at-home kits. They are not very strong. Go to a dentist.
I do not usually frequent this side of Woodcentral. I'm most likely found on the spinning side. If you've got questions, contact me off the forum.
Cheers,
Steve Kubien
-who spend waaaaay too long in the dental industry.
Nat Robison
>My wife and I both use a whitening system from our dentist. The over-the-counter products are something like 5% peroxide while the dentist's product is 22%. We had to have molds of our teeth made at the dentist and then received the custom "trays".
Refills of the whitener cost $75.
If you use it 1-2 times a day for 20-30 minutes, you'll see results pretty quickly. Like the previous response mentioned, it won't bleach porcelain, bonds, etc.
Or... A woodworker's approach
>Instead of whitening your teeth, you could increase the contrast by darkening you face. You already have a lathe don't you? Just turn a walnut bowl and sand it to about 400 and "wear" the sawdust. I have found that my face is the most effective dust collector in my shop. Your skin may be finer textured than mine, just sand to 600.
(no need to thank me, or listen to me either)
I agree with Steven
albertabob
>First I agree with Steven.
Most "bleaches" are primarily Carbamide peroxide in a aqueous gel.
Some have flavours. Some have a hint of calcium and or phophate which may or may not remineralize your bleached out teeth.
The pricing for these products is mostly a factor of marketing as there can be little difference in carbamide peroxides of the same strength.
Discuss this with a dentist you can trust and make up your own mind after you know all the facts.
Good luck
Bob
Re: Or... A woodworker's approach
>Uhhh... thanks, Barry.... I think...
steve - Denver
>I've had whitening done by the dentist (trays with a solution you wear at night) and veneers put on my 4 top front teeth. Whitening works well and I'm very happy with the veneers, they're 6-7 years old. Worth every penny I spent on them, just wish I had done them sooner. I did a face plant off my bike growing up and landed right on my mouth so my front teeth have always had some issues.
I would whiten 1st and then any veneers you want can be made to match your whiter teeth. They also have laser whitening, which I've heard works well.
