New Table Leaves Finally Finished
Garrett in Victoria
>With advice from my WC friends, I finally finished the new table leaves.
Background: we purchased the table and 8 chairs (plus other furniture) in a hurry about 18 years ago as we were finishing an assignment in Kuala Lumpur and about to return home. Then we discovered that the 6 side chairs didn't fit between the legs with enough space to spare, i.e. they were going to be dinged. Consequently, we down-sized our dinner guest lists. However, a few months ago, for reasons completely unknown to me, SWMBO suddenly decided we had to extend the table.
It already had a single 24" leaf, and we determined that another 16" would do very nicely, but since that would look awkward, decided on a pair of 8" leaves. However, the original table ends and leaf have floating panels and 3" wide frames, so there would not be enough width to emulate them in the new leaves. However, the large credenza in the background of the photo below has inserts of slate in its top. I still have some matching pieces of that slate, none quite big enough to provide a single panel in each leaf, but enough for 2 pieces each with a centre divider. So much for the design.
A local tile company cut the slate for me while I watched for a price of $5 for all 4 pieces! (It's surprisingly soft, BTW.)
The table's made of a tropical hardwood ubiquitously termed Chinese rosewood, of which I could find none locally, but I did have some Honduran mahogany that was pretty close. I used a 3/4" plywood underlay, milled the mahogany framing to the same thickness as the slate, and glued them up with the slates in place. I glued another set of frames to the bottom, as had been done with the originals. The rest was hand work to match the tricky apron profiles. I also made a pair of longer extension runners.
I got into trouble during the finishing. My wife has a real eye for colour, and she mixed up a complicated oil stain with greens, browns and reds that's so close to the original, it's a wonder. When that was applied I started laying on satin wipe-on poly until I had a good base, then rubbed out with rottenstone and water as a lubricant. But, didn't use enough water and made a mess of it. No sheen and cloudy. Bill Tindall responded to my plea on WC for suggestions, and provided some very helpful corrective advice for which I am most grateful.
I carefully hand sanded as much of the finish off as I dared - didn't want to hit the stain - and ended up at 320 grit. Started over, this time with gloss wipe-on poly. Many coats later, sanding lightly in between with 320 paper, I went over the final coat with 400 grit paper dry, followed that with 0000 steel wool lubricated with varsol, then rubbed it out with rottenstone and water until I had a sheen that matched the original. A coat of well-buffed Minwax paste and at long last:
The aprons
What was to have been a small, fun project turned into a sometimes frustrating saga, but SWMBO is delighted with the outcome, and suggested I refinish the rest of the table. No way! But I will get the dust out of the crevices.
Cheers, Garrett
Re: New Table Leaves Finally Finished
>Good Evening Garrett,
Our leaves are about finished down here, too. That is a wonderful addition, very creative. Gutsy, successful coloration which I'm sure gave you anxious monents. Neat skirt work too. Excellent job.
George
As we grow older & older, we are eventually.......
Art Silva
>struck with the realization that most aggravation is self-inflicted.
Outstanding work Garrett, now calm yourself.
Clay Foster
>Really good job, Garrett. You can be proud of that.
Bob Lemon Sacramento Ca.
>Garrett, I took the liberty of enhancing your picture to better show the inserts. Very nice job. I like the chairs too. Bob
Thank you!
Garrett in Victoria
