Bamboo Flooring
Bamboo Flooring
Bamboo Flooring
Ray DuBose - Memphis TN
>Only done some tile laying in my life. Wife wants me to pull up the carpet in the living room and lay Bamboo Flooring.
I've looked all over the place to see what the best way to lay this stuff on a slab and every article starts off with laying it on top of plywood. Well that's great if you have plywood flooring underneath but this is directly on a slab. I don't want to raise the floor up so I would rather not lay ply on the slab and put it on top.
I'm in Memphis TN and there is a water table and I plan on doing a test on the slab this weekended to see if any moisture is coming up through it but from what I understand from others usually not.
So the Big Box Stores said to use polyurethane glue and just trow it on and lay the stuff. They say the Glue will seal the slab and everything will be A-ok. From past experience I don't 100% trust the Big Box guys as they sent me down a few home upgrades the wrong way. So I thought I would ask you guys. Any Ideas?
Also my other thought was to Float the Floor. This is prefinished Solid Bamboo, tongue and grove and fits pretty tight together. Anyone out there Float a Floor (ie, not glue it, just lay it and stick 1/4 round around the baseboards to hold it down?. Maybe put plastic down beforehand to seal the floor or a wood floor foam pad down. My thought is if I have to do any repairs it will be a lot easier. Having 2 kids makes me think I may have a few in the future.
Any Ideas would be appreciated. I know this is not a flooring form but seems all questions get asked here eventually.
Thanks!
Ray
Re: Bamboo Flooring
I'm in Atlanta....
>...on a slab. I thought about bamboo flooring and decided against it for two big reasons.
1 - I had oak flooring glued to the slab and it was horrible for mold growth, etc, so I HAD to have a floating floor with extra vapor barrier and padding for peace of mind.
2 - A friend put bamboo flooring in his house (living/dining rooms) over a plywood floor (he has a basement) and within 2 months the floors were badly scratched and dented and looked terrible. We were both surprised at how soft the bamboo flooring was. It wasn't supposed to be, but it was.
So I put down a floating laminate floor and couldn't be happier. It's warm in the winter, cool in the summer, completely moisture/mold/smell free, and looks great.... and industructible.
Well.... there is one part of me that doesn't like the fact that it isn't real wood...... I love real wood..... all my furniture in my house is solid wood.... no plywood, laminates, etc...... all solid oak, maple, etc.... I really love wood.
But any natural wood flooring just doesn't do well on a slab..... not here in the south.
Happy Woodworking!
Re: Bamboo Flooring
Re: Neighbor ripped theirs out
Brian in Brighton
>Our builder had bamboo put into the spec home next door. The owners had so many problems with it that they had the builder rip it out and replace it with Brazilian Cherry. No problems with it.
It was unstable and warped bad. Of course we're in Denver where high humidity is about 50% of yours :-)
I would ask some professional installers in the area what their experience is with it and what they would offer for a warantee compared with other material.
Brian in Brighton
Re: Bamboo Flooring
I'm in Houston
Basil Biberdorf
>I'm in Houston, also on a slab. I just replaced a lot of downstairs carpet with laminate (from Quick-Step). I used Quick-Step's own foam barrier, and it works well enough. I don't care for the acoustics, but, with three children, two cats, and a dog, I very much care that it's extremely durable. The floor itself is embossed with the "oak" grain on it, and it feels very much like wood under the feet.
With regard to wood or bamboo, they make a glue that actually forms a plastic moisture barrier. The problem is that it's expensive (like $30 a gallon, IIRC). In a climate like this (very humid much of the year), I would certainly use such a glue with natural flooring.
My parents-in-law just installed bamboo, about two months ago. I'll see how it holds up.
Re: Bamboo Flooring
Re: Bamboo Flooring
Mike B.
>Not too sure how to overcome the problem about the moisture, but I definitely would not float the floor unless it is snaplock. After a a few temperature changes you will have gaps between the boards everywhere. As far as advice, I layed a similar prefinished floor in January of this year. I started out using the manufacture recommended procedure of merely gluing it to the floor. Not a piece of cake, as the first boards like to move about as you try to butt the second ones to them. I rectified this problem by breaking out my brad nailer and tacked each and every one in place at an angle through the tongue, of course this was into plywood though. Why am I saying this when you have concrete? Be prepared to find a way to overcome the movement of the first boards or you will fight them the whole way. Also, don't be afraid of having to replace any of the floor. It is a lot sturdier than you may initially think, as I had my doubts at first. But after almost a year of abuse, my still looks as good as the day I layed it. Hope this helps some, and good luck.
Re: Bamboo Flooring
Re: Bamboo Flooring
Joanne Adler in Pt. Pleasant, PA
>Whose Bamboo Flooring are you planning on using? This is off the Teragren website. No experience with their bamboo; I just know they make it.
Can your bamboo flooring be glued directly to concrete?
All Teragren bamboo flooring products, with the exception of STUDIO Wide Plank Floating Floor with TeraLoc, are suitable for a glue-down application to concrete with a premium wood adhesive such as Bostik�s Best adhesive. As always, check for any moisture problems in the concrete first
Re: Bamboo Flooring
There's TWO types of moisture
>There's water and there's water.........
No seriously though...... there are two sources of moisture.
1 - Moisture from below - from the concrete slab, which is 100% eliminated by 6 mil poly, and perhaps 50%-90% eliminated by the adhesive. Trouble is if even 5% gets through the glue adhesive it can cause mold (as in my case).
2 - Moisture from above - from the room. Which was also a problem for me with the glued down flooring. The flooring was cold, because it was glued to the concrete slab, but moisture in the house would condense and settle on the top of the flooring sometimes. This would happen if we opened the front door for more than a few seconds and the hot moist air from an afternoon rain storm (not in the last year with our drought mind you) would come in the house and touch the cold floor. The moisture would lie on the wood floor and get into the cracks and pores further complicating the mositure problem.
With the laminate flooring it's not an issue. The 6 mil (2 layers) over the slab takes care of that, and the top surface of the flooring is pretty much waterproof. And because the floor is insulated, it's not cold like it used to, so the moisture laden air doesn't condense immediately on the floor anymore.
Happy Woodworking!
Re: Bamboo Flooring
Howdy Neighbor
Tony - Memphis
>We did our breakfast room floor with a floating "engineered" floor a year or two ago. We used a Pergo product that we got at Lowes. I haven't seen it there the last few times I looked (glad I have some left). We have a slab too. We floated ours right over the old vinyl floor covering that was on top of the concrete. We put down a layer of the foam underlayment. This floor system is glued edge to edge - t&g. I made my own transition pieces. It was pretty easy to put down and has held up real well and we are very please with the looks of it.
Tony
Re: Bamboo Flooring
Re: Bamboo Flooring
ScottS
>At this time, I would be very wary about putting down a bamboo floor. There are lots of companies flooding the market with bamboo and it's very difficult to tell who is reputable and who isn't. At the time I looked, none of the large well-recognized flooring companies were selling bamboo flooring. When I replaced my floor last year, I really wanted to use bamboo! After doing a lot of research, I decided that there wasn't a bamboo product that was really designed for a floating or glue-down application on a concrete slab. In addition, I obtained flooring samples from several different vendors and did my own informal, completely unscientific durability tests. My conclusion was that bamboo I received wasn't any more durable than any other hardwood flooring and some appeared to be less durable, despite all the hype about Janka hardness tests.
In the end, I gave up on the idea of bamboo flooring and went with a Quick-step laminate. It's not wood, but I think it looks pretty good! It was easy to install and designed for a floating installation over a concrete slab. Durability is great! My dogs run around on it all the time and have yet to scratch it; I'm pretty convinced I couldn't say the same thing about any hardwood or engineered wood product...
Re: Bamboo Flooring
Re: Bamboo Flooring
Neal in San Jose
>at work. I wouldn't wish it on my worst enemy. It swells and shrinks more than any natural product I've ever seen; it is soft; and it never stops warping and moving. Other than that, it is ugly. Anybody got a match?
Re: Bamboo Flooring
Re: Bamboo Flooring
Bill White
>Gotta remember that bamboo is a grass. I think I'll stay with wood.
Bill
Re: Bamboo Flooring
Re: Bamboo Flooring
NickB
>From what I've read about bamboo, it doesn't develop the high levels of hardness until after the 3rd or 4th harvest (or something like that), and a lot of (johnny-come-lately and less reputable) manufacturers are using early harvest material. There's also a difference in the way the material is oriented (I can't remember which side is harder, but there is a difference). Take home message for me was to avoid cheap bamboo flooring.
Nick
Re: Bamboo Flooring
Re: Bamboo Flooring
ScottS
>I get the feeling that there are also a number of bamboo species that grow large enough to produce flooring. Some of them are actually suitable for this purpose... and some aren't. Everybody likes to quote the Janka hardness test numbers for the hardest species available, but that does not mean you're actually getting that species in your flooring!
