Window muntins
Window muntins
Window muntins
Bill Lordan, Auburn NH
>Hello Everyone;
The LOML has wanted me to replace our damaged window muntins for quite some time and I would like to get this job done for her before Christmas. I had bought the profile router bit in order to do the job but I am a bit intimidated by all the precise miter cut needed to have the muntins interlock correctly. My question is this: Does anyone have a quick, simple way to produce these muntins that would look half way decent? I have searched the web and for the most part I have come up empty handed. Any help will be greatly appreciated.
Bill Lordan
Auburn NH
Re: Window muntins
Re: Window muntins
Steve Mackay
>I'm just a hack and build really detailed models and I quit struggling with meiter box and such. Now-days I chop the stock, mark my angle then hold it to the bench sander and grind to the line. Hold your bevel gage in the other hand and check it repeatedly. With this method I hit more than miss. I know, I know, I wouldn't do this with a room of moulding but for the small stuff it works pretty good.
Re: Window muntins
Re: Window muntins
Charles M
>The best way is to avoid the miters and use coped joints whenever possible. Which bit did you get? Is there a negative/cope profile available for it? Are you making simulated divided lite or true divided lite?
Charles M
Freud America, Inc.
Re: Window muntins
Re: Window muntins
>Charles;
I tried to upload a photo but was unsuccessful. I just have the one profile bit. The muntins interlock with a 1/2 lap joint which has a 45 degree bevel on each side of the joint. I realize this is almost impossible to picture and I will work on getting a picture posted.
Bill Lordan
Re: Window muntins
Re: Window muntins
Hal Smith
>Possibly as much as a couple of years ago, Bill Hylton had a pretty good article in PopWood. Good luck.
