Substrate for laminate countertops
John E
>I'm helping a buddy make countertops for some garage cabinets. I've done this before, and used AC plywood as a substrate for the laminate, which worked well. But I was thinking that MDF might be better (or just as good) and cheaper. Besides it being freakin' heavy, are there any other pitfalls to MDF? Any worry about sagging? (Countertops will be 24" front to back).
Thanks,
John
Re: Substrate for laminate countertops
Terry Alexander
>I used to do this for a living working my way through college (Uh...a long long time ago). However, the "preferred" substrate that I still use and recommend is 3/4 particle board. Super smooth finish that contact bond (get the highly flammable kind...that water based "stuff" just doesn't do the job) sticks to very very well.
Front drop edge is a 1" x 2".
Respond if you have anymore questions. Be glad to assist. (I'm much better at this than I am woodworking...but I keep practicing and end up making little sticks out of big sticks ;-)
Terry Alexander
Howard Acheson
>MDF or particleboard will work just fine. Most kitchen counters use one or the other. Both are flatter than an AC plywood. But, they are heavy.
David Hay @ Denver
>In the reading I did before making our kitchen countertops, most suggested using particle board as the substrate. That being said, however, the countertops I replaced were glued to some sort of plywood, and were still in good shape some 20 years after they were installed (just ugly ;)
David
Odd man out...
Gary Camp, Bend, Oregon
>While I know that the pros use particle board, for the previously stated reasons, and I know that those are good reasons, and I know that it is considerably less expensive. I really prefer to use 3/4" MDO, at least if there is any posibility of contact with water. I have had too many countertops "blow up" due to moisture. Admittedly these counters see much higher useage than a residentail application. Public restrooms, coffee counters etc. one back bar is swelling just from moisture from a sweaty window. Oh yeah I also use water based contact cement good success. Addmittedly I do not do that much laminate work, nor am I trying to do it in a production situation.
glc
