Delta DP As mortiser questions?
>I have a Delta/Rockwell DP I have had for about 36 years. Only in the last three or four years have I started to use the mortising attachment. (Had It all along, never used it) It had a ring on the bottom of the shaft that the depth stop rides on. You take that ring off and install a yoke that the mortising bit fits in and it also has the depth stop on it. There is a set screw in the side of both the ring and the yoke that engages a slot in the shaft of the DP. (I think, I don't have the instructions). The position of the hole for the set screw is clearly different. The top part of the yoke is identical tot he ring, except the yoke is added and the set screw is about 3/8" lower that on the ring. In fact, it does not go through the ring at all, but goes through the side of the yoke. Seems to work OK and I only noticed it because I change the set screws to thumb screws so I don't have to find that little screwdriver to switch back and forth. (Pet Peeve, having to find umpty nine different tools to change something that could have been done with one.) Now I am wondering if mine were mismanufactured? Does anyone else have a similar set up? Are both your set screws centered on the ring? Does it matter.
