Way OT, Blood pressure Med Question?
>I have been taking blood pressure medication for a few years. I am convinced it depresses me and takes the joy out of life. I mentioned it to another doctor and his response was "Ooh! Depression in a bottle. I am surprised you can get off the sofa and do anything."
This is slightly Wood Working related. I could get more woodworking done if I weren't so bummed all the time.
I am about to go for a check up and thinking of asking for a change to a different med. So the question is, have any of you noticed the same sort of thing? What medication? And conversely, are any of you on a BP med that does not do this?
Re: Way OT, Blood pressure Med Question?
Tim Greif - West of Chicago
>I went through a couple different ones befor settling on Altace and Lisinopril. They're both ACE inhibiters. My doc switched me to Lisinopril after our company presription plan stopped covering the higher cost for Altace. Neither one gives me any discernible side effects.
Rod Peterson -*- Ormond Beach, FL
>I have had varying needs for BP medicine for several years. I spent most of my air traffic control years not having a BP issue, although it was always in a marginal range. About two or three years after I retired, it crept high enough that my doctor put me on one (I don't remember which brand or which type), and I was on that for a while when I had a syncope which was later determined to be a result of hypo-tension, and he reduced the dose.
After a period of weight loss, due, probably, to a bout of pancreatitis due to a blocked bile duct, and which resulted in a laparoscopic cholecystectomy, my BP had retreated to a point where my doctor took me off of it. I stayed off for several years until my weight slowly surpassed my previous bloat and there was a concomitant rise in BP to the point my doctor (different doctor than before) put me back on one (Enalapril, this time).
I have since quit drinking soft drinks (last April) and my weight has dropped a bit (about 15 lbs) as has my blood pressure. I reported it to my doctor on my last visit as well as my history of syncope and hypotension and he suggested I stop taking it and monitor, with half doses PRN. So, as it stands today, I'm generally not taking one. Over the years, I believe I've had both ACE inhibitors and calcium channel blockers.
I said all that to make two points, one perhaps helpful, but neither directly answering your question. They are A) I don't recall any lethargy or depression beyond any usual (for me) afflictions, and 2) my doctor has been preaching weight control in conjunction with a better BP outlook for some time. I'm not saying you have a weight problem, nor that there aren't other reasons you might have to control it with medication (family history, for example), just that weight control and exercise may be a big help in avoiding medication, if it's possible in your case.
Rod
Lee Ohmart
>I'm a practicing pharmacist and hear this complaint from hypertensive patients frequently. The antihypertensives that are usually the culprit are the beta-blockers. This class of medications are further broken down into two catagories, lipophyllic (fat soluble) and hydrophillic (water soluble). The ones that are highly lipophyllic, like propranolol, are the worst in side effects involving the central nervous system. Patients taking these complain of feeling sleepy. This goes away somewhat with continued use. The ones that are highly hydrophyllic, like atenolol, do not cause this side effect as much, if at all, as they cannot easily pass the blood-brain barrier. A commonly used beta-blocker following heart surgery is metoprolol. This falls about midway between propranolol and atenolol in it's hydrophyllic/lipophyllic properties so patient side effect response is variable. All of them lower blood pressure by lowering heart rate and allowing the peripheral blood vessels to expand. Because of this they share the property of lowering the threshold of fatigue. Some of my patients adapt to this while others end up being switched to other antihypertensives. The exception to this if the post-surgical patients who usually are kept on the metoprolol by the doctors as it protects them from future heart problems. Diabetics should be on an ACE inhibitor or an ARB as these are protective of kidney problems common in diabetics. Most of the patient here at the health center are started on an ACE inhibitor. If their response is suboptimum, a diuretic, usually hydrochlorothiazide (HCTZ) is added. Beyond that they might have a calcium-channel blocker added. Patient's response varies and certain ethnic groups respond better to different medications. The best thing for you to do is talk with your prescriber about this problem. Then, the two of you can work together to find a medication regimen that works for you. Oh yeah, ditto on the prevous post about lifestyle changes. Diet and exercise make a huge difference for hypertention secondary to obeisity and diabetes.
Sean Troy
>I take lisinopril for years now with no side effects.
Going to Be Back by Next Weekend?
Mike Fitterling
>See the post below. Get-together at my shop on the 1st. Hope you can make it!
Cheers,
Mike
Re: Going to Be Back by Next Weekend?
>I saw that, Mike. Although I think we're leaving here Wednesday (to return Thursday), I haven't broached the idea of immediately taking off again two days later to you know who. I'll so broach somewhere around Kentucky or Tennessee.
I'd like to, but I may be road dead, too, by then.
Rod
Mike Schwing from Md.
>It would help if you told us what you were on. Many BP meds can lower heart rate. They sort of put a rev limiter on you and yes, it can feel tiring and depressing.
I had been on a couple of BP meds because occasionally they are used for migraine preventives. One of them lowered my waking heart rate to 30bpm, and dropped my resting HR by 10bpm. As an endurance athlete, mine is already very low and I couldn't afford the add'l drop. It made doing everything tiring, and this depressed me.
I would agree with Lee...
John E
>I'm a family doc, and depression isn't that unusual on beta-blockers. There are some conditions where beta blockers are the drug of choice, but assuming no other health problems, ARB's or ACE inhibitors for the treatment of hypertension are usually very low if any side effects. By all means, talk with your doctor about this. (Whatever you do, DON'T just stop taking it without giving your doctor a chance to try something else, or at least explaining why your particular medication may be the best choice for you!)
John
Hmmm?! How'd That Happen?
Mike Fitterling
>I thought I had replied to your post down below in Woodworkers Weekend Accomplishments. Oh well.
Just let me know if you think ya'll can make it. I don't think this one will be as big as they aften are, but you never know.
Cheers,
Mike
Jason Roehl in Lafayette, IN
Ellis, here's another one...
>...where the message view does not contain the links to the other messages in the thread. Just thought I'd give you a heads-up.
Just to be a bit on-topic: my BP is typically about 110-120/60-80, so I know nothing about the associated meds.
Jason
I see the same thing, thread issue.
Dan Donaldson
>Windows XP pro (custom oem load) IE6
Re: I see the same thing, thread issue.
>Oops...forgot the particulars:
WinXP Home SP2
FF 2.0.0.9
Jason
Absolutely ...do not perform any experiments
Chris Knob
>Stay on your meds. Any bouts of depression in your medical history prior to the medication?
Andy Halterman: Don't taze me bro
>Barry,
I didn't go through all the other responses but I feel your pain. When I first started on BP meds, they gave me something that reduced my heart rate. Now, I'm an avid cyclist and I have a hard time sitting still unless I'm really tired. Every time I'd try to ride/hike uphill I felt like a snail stuck in tar on a cold day. Not good. I pleaded with my doctor to give me something else. Fell on deaf ears. Got a new doc and he hooked me up with a medicine called Diltiazim (?) or something close. I believe it's a calcium channel blocker and it works like a charm for me. The only side effect I've noticed is an increased sensitivity to dehydration. I get wicked headaches and slight nausea if I don't drink enough. Not really a bad thing cuz it keeps me chugging water on a regular basis. Only drawback of that is when someone is driving me on a longer trip and I've got to stop every 1-2 hrs. for a pit stop. :-)
Better living through chemicals.
Andy Halterman
Actually experiencing some measurable precipitation here in Hendersonville, NC�
Paul Leuba
>After several years of marginally elevated blood pressure, it crossed the threshold to high and my doctor put me on 10 mg lisinopril with 12.5 mg HCTZ, as I recall. I immediately began to experience fatigue and lethargy. He removed the HCTZ from the prescription and left me on the 10 mg lisinopril which has done the trick. BP is back to normal range and I have no noticeable side effects.
Good luck with it.
Paul in Hunt Valley
>I'm on Atenolol, 50mg. I'm 20/25 pounds over weight and out of shape. This runs in circles. I have picked up the weight since I started the meds. It's hard to stay in shape and at your weight when you don't ave the energy to do anything.
Ken Oakley-St. Cloud, Fla.
>I take 40mg Quinapril and 2.5 mg Indapimide to control my BP. Maybe that is why I do'nt have the GET UP and go I had 25 years ago at age 50. It may also be the reason I need a double dose of Viagra at times.
Maybe I'll start runnung.
I hear ya champ!
Dominic Greco in Richboro PA
>Barry,
I am currently on Avalide and I found that I get much more easily fatigued than I used to.
Due to sinus problems, I am prone to frequent sinus infections. When they used to hit me, I would get tired. Now that I'm on Avalide, I find that it takes most of my strength to just get moving. They really knock me out.
One way to find common side effects is to google the name of the medicine you're on, coupled with the phrase "side effects". You'd be surprised what you find out.
Working out and loosing some weight has helped. But I need to change my diet (more) so I can lower my BP and get off this damn medicine.
See ya around,
Dominic
I'm in a World of Trouble now!
>Went to the Doc today and he changed the medicine to Lisinopril. I have to taper off the old stuff and start the new stuff. I have also been ordered to get into shape and lose some weight.
This is like computer dating. You know, where you fill out the highly scientific questionnaire and you find out who you really deserve.
So now I have a chance to find out if it was the medicine depressing me and making me lethargic. Or the truth may be that I am just old and lazy. Frightening.
John Veerkamp
>Barry,
I'm 64 and have been on Micardis for 1 year. I don't have weight to loose and tried all of the lifestyle remedies with little effect on the BP. My Doc says it's not always weight ,, diet and exercise problems that cause high BP. I've had no adverse side effects to the medicine and one significant good side effect. I've suffered from migranes for 50 years and the Micardis has significantly reduces the occurance and severity of the headaches. It has reduced my 30 on the high side and 20 on the low side. Works for me and I'll continue.
John
Re: Linsopril is pretty tame stuff...
Glenn Madsen near San Francisco
>At least for me. And my doc told me it was what he takes. No way to verify that, but I have to believe something.
The best thing is that you discuss the challenges with your doc. There are a bunch of reasons for the things we experience, and docs are fairly well prepared to look at some of them.
Probably at least as well prepared as your Internet woodworking buddies... ;-)
Alan in Little Washington (NC)
>I don't have high BP, never did, but have Coronary artery disease that resulted in a heart attack and a quad bypass 10 years ago. I have been taking Atenolol since then. I have been training and competing in swimming in the Senior Games for the last four years. I never really researched to find out what Atenolol (a Beta blocker) did until a year ago, and was shocked. It keeps my heart rate at 120 BPM or less no matter what I do! At my next Dr's visit I asked about this and hypothesized that, based on my previous training heart rates, this stuff is limiting my heart's pumping by up to 30% and my oxygen uptake and lactic acid purging by similar amount? He said that's about right!!!!!! It sure makes it hard to train and compete with that kind of handicap. I didn't take my pill before the last day of competition at Nationals this summer and did much better in one event!!! Man, ain't gettin' old hell!!!!
This thread has been helpful
henthorn
>I was feeling poorly (to put it mildly)last year and was diagnosed with polycythema vara. My platelet count was three times normal and I was really fatigued and lacked energy and endurance. After several months of treatment (no cure) my platelet count is pretty normal. I had been taking verapamil for BP the last twenty years. My heart doc changed me to Avalide, then doubled the dose. Then my regular doc added amladopine and then doubled the dose. I was told when my platelet count was straightened out I would feel more normal, but I am still fatigued and my strength and endurance and energy level are still pretty poor. Guess I need to talk to some doctors.
