Strange air leak question?
>I move my DC and Air Compressor out into an Exterior closet in back of my shop a year or two ago. I leave the Compressor "on" all the time so that I have Compressed air available. The timing is a little vague here so bear with me. After a while I noticed the compressor would run occasionally even if I were not in the shop. I checked for leaks and found none in the hoses and fittings. (Just a fifty foot hose run in through a hole in the wall.) I started to turn the compressor circuit off when I left the shop. Later I fell out of the habit and noticed the problem had gone away. So, now the mystery leak has reappeared. I realized I was reluctant to go outside and search for the leak because it is cold out there. Then I wondered if it was the cold causing the leak? Is that why it came and went? Is there something about a compressor that would leak in cold weather and not in warm?
I fear the leak will get much worse and I will come home to a burnt up compressor or worse a burnt up house. Not to mention the waste of electricity.
