Battery question
Barry Rubenstein
>I don't do electricity well so here's my question. I have a Milwaukee cordless drill and need new batteries. It came with 14.4 volt batteries but would there be a problem if I use higher voltage batteries ?
Battery question
Barry Rubenstein
Re: Battery question
Don Evans
>The short answer to your question is "yes" there is a problem with doing that.
You have a drill with wiring and motor that was made for that voltage and that is all that should be used.
I think if you try to do it, you'll discover that manufacturers make each battery differently so that it will not plug into the drill. In other words a DeWalt 14.4 volt drill will not take a DeWalt 18 volt battery. The ends of them are made differently for reasons of safety and to keep you from burning up a motor made for a lesser voltage.
Think about your car or truck, it has a 12volt battery in it, all things in the car are made to run on 12 volts, radio, mirrors, plug coil etc etc. Put 2 batteries in it wired in series for 24 volts and first time you turn on radio it burns up, so does cig lighter, remote mirrors motors etc etc.
For someone who comes back and says my truck has 2 batteries in it, yes but they are wired parallel so voltage is still 12 but amperage goes up.
So in your drill you can use a 14.4 volt battery that has higher amperage and that is ok.
Don
Long ago and far away........
Basil
>MACK trucks came with 4 six volt batteries, 2 wired in series to produce 12 volts and the other 2 also wired in series to produce 12 volts. They inturn were wired to a series-parallel switch so as to produce 24 volts for starting the engine and then reverting to a 12 volt system after starting. The truck wiring, lights, generator/alternator, everything was 12 volts except the starter.
You really didn't need to know that, did you. .....LOL
Re: Long ago and far away........
Jason Roehl in Lafayette, IN
>Ahhh, but it was an interesting factoid nonetheless. It sure makes a lot of sense, too--starters draw an immense amount of current that likes to fry marginal components. Bumping it up to 24V halves the current needed to get the same energy to spin the engine.
Jason
