How to test rechargeable batteries?
JohnM in Mid Michigan
>I have an aging 9.6V Ryobi drill that I've always liked, but that quit some time ago. Today I decided to investigate. After finding no voltage at the contacts of the charging station, I did surgery and the little circuit board inside was charred to a crisp. So I know I need a new charger, but I understand that a bad battery might have caused this problem in the first place. I'd hate to buy a new charger, plug in a bad battery, and fry it again! Can I test my two batteries to see if one or both are bad? How? [And yes, I know how inexpensively one can get complete new replacements - SWMBO got a brand new one for her hobby room at HD the day after Thanksgiving for $19.95.]
Re: How to test rechargeable batteries?
Bob Entwisle in NJ
>Measure the open circuit voltage on the batteries. I belive your 9.6V battery pack is composed of 8 1.2V nicad cells in series. If you are much below 8V then one or more cells are toast.
While there are ways to make the battery pack come back up to full voltage, you will probably not be able to restore them to full capacity.
Interesting science experiment John...
Chris Knob
>but like you said, these are basically disposable units and with replacements for under $20...jeeeze, I'm old enough to remember when $20 was a lot of money!
I've pitched at least a couple of what basically amounted to "rechargable screwdriver" drill sets in the last 20 years. A bargain 9V rechargable drill package, nicely boxed up in a blow moulded case with a charger and extra battery included for $29.99 under the Christmas tree just screams disposable.
>But the batteries aren't charged... Don't I need at least some charge on them in order to check voltage?
>A local tool repair/parts company has a tester that can check batteries and put a fast charge on them. I have had my 12 volt ones check a couple of times. I actually don't know if they can do 9.6 volts but I suspect they can. I had mine rebuilt for about $50 each, but if I could have gotten new ones for $29 or even less than fifty, I would have been right there.
Bob Entwisle in NJ
>If the battery has dropped below 8V then you will not be able to charge it. A fully discharged nicad battery, after a short recovery time, should still show an open circuit voltage of over 1 volt per cell, which in the case of a 9.6V nicad pack would be 8V.
