OT - Backing up old computer hard drive
Doug Thompson near Cleveland
>I finally broke down and bought a new desktop computer. The old computer a HP 667 running 98SE has been around for a long time... to long. The information on the hard drive with 10.6GB needs to be saved, links, pictures and old email.
The external hard drives sold today only support Win 2000 and not 98.
I have tried to save files to a laptop and still find myself going back to the old computer.
How can I save the information?
Re: OT - Backing up old computer hard drive
Ron in Drums PA
>Do both computers have a network card? If so, set up network between the two systems.
You'll need to use cross over cable to link the two together.
Other option... Transfer your data on CDs or DVDs.
Binen
>You can probably just install the old HD as a second HD in your new computer. None of the programs will work but all your data files will be there. Not sure about your old emails since they are generally saved within the program. You could also try using a USB jump drive, if your old computer has a USB port. A 4 gig jump drive can generally be found for under $50.
Binen
Pete Stahl
>I bought a COMPUSA 3.5" External Hard Drive Enclosure and now I can transfer files easily from the old drives that were in my PII. My old Pentium II had a 10 GB and a 80 GB hard drive in it. One had Win 98 on it and the other Win 2000. You put the drive in the enclosure with the jumper on Master, plug it into the USB slot and the PC did the rest. I was able to transfer file back and forth between them. There are a lot of manufacturers of these and the old drives are IDE drives not the SATA like the new ones. You can't put a SATA drive in a IDE External Hard Drive Enclosure.
>This old computer should have a 3.5 inch drive? I think so. Bestbuy is around the corner so I'll try a 3.5 enclosure first.
All the emails are from AOL that's updated on the old computer, I know AOL is not the best but my whole family uses the account so I can't get rid of it.
Thanks for the help, this has been driving me nuts! LOL
Doug
Brian
>Kim Komando pushes a company called Carbonite (Carbonite.com). They offer 30 days free (with no credit card required) of data backup. Use them to backup then do your transfer and don't sign on after 30 days. Nothing unethical or illegal about it.
In your new PC, make the investment and buy a second HD and do an image backup with a program like Acronis. It allows you to restore both data and system files in the event of a HD failure. Relatively short money for the home user ($49.00).
Very easy
Bill Hammond, Oregon Coast
>Just temporally remove the hard drive from the old computer. Now unplug the data cable from the CD rom or DVD of the new computer and plug it into the old drive, find a power connector in the new computer and plug that in. The drive can just be hanging there no need to install it into a drive bay. Or if you are lucky, the cables will reach and just put the two CPUs side by side. If you do this do not power on the old computer, data and power cable must come from the new computer.
Now boot the computer, it will find the drive, complain perhaps about the missing cdrom/dvd. Once it is up and running in the root of C: make a directory with a name like OLD STUFF. Now using Windows Explorer just drag everything from the old drive to the directory. You will get some error/do you really want to do this messages about copying system files and the like. Just say yes and check the box about all the rest of the occurrences. It will stop like that several times and then just chug along with the copying. Remember you want to copy and not move the files
When done, put all back as it was. Now recycle the old computer to someone who needs one or as something use full for yourself. If you give it away, wipe the drive and reinstall Win98, it's patches and updates, they are still available from MS.
If you had a lot of nifty fonts they will be in Windows\fonts. Your applications will have saved a lot of data in C:\windows\Application data\ directory or c:\windows\Profile\user name\application data. Some applications may store data with the application but most of what you want will be in c:\windows\Profile\user name\my documents.
I do this on a regular bases, it is by far the fastest and easiest way to make the copy. To copy the drive over a lan will take hours longer. If you copy to cd just the stuff you need you will for sure miss something important.
Have fun,
Bill, your mileage may vary, void where prohibited by law,
Chuck W
>One thing you could try is to email all your important documents to yourself using your old computer. Then use your new computer to receive the emails with the attachments. If you have DSL then it may work. With Dialup it won't work. AOL may limit the size of the email possible.
Does your new computer use Sata or IDE? If you plug in your old drive to your new computer then all you need to do is copy over the "My documents" folder to the new computer.
