What would you do with a piece of bowling alley?
Mark_in_Michigan
>I have had a 40" x 44" piece of bowling alley in my possesion for at least 10 years. Before that, the neighbor that gave it to me had it for at least 20 years, so this piece is old. It is the very end where the pins go down. I pulled out the black plastic discs the pins rest on because there were in bad shape. There are several metal rods that run all the way through it.
I kept it thinking I would build a butcher block table one day, but we just moved into a new house that already has a kitchen island and no room for another table.
Yesterday I finally got out the belt sander and went to town, sanding both sides and the edges, the idea being flatten it as much as possible (neither side was flat), get all the old finish and wax off and to see if it was even worth using. It looks pretty good now, I am guessing it is maple. It has some gouges, but it is usable.
I thought briefly about making a workbench with it (which I don't have), but because of the off size I wasn't sure how useful it would be.
The only other use I can come up with is a table to use in my Pole Barn. I would make it high enough to use with bar stools and probably put Walnut discs in where the plastic ones were and put on a Walnut border, using a clear finish over the whole thing. I also have some old 5x5 pine posts I could use as legs, which I could get creative with on my Legacy mill.
This doesn't seem all that creative so I thought I would ask here what others might do with it.
Thanks.
Re: What would you do with a piece of bowling alley?
Jerry Burns
>I have a 6foot bench made from an old bowlling ally my bil has an 8 foot x4foot chunck that we are going to make a stand for for his bench
Steve Mackay
>When they demo-ed the alley here at Fort Bliss I tried to get some but it was in the contractor's contract to take it. He peddled it off for premium bucks. I always though it would make ducky work benches / stations ( I had move-able in mind ). I would think its very stable, true and heavy-duty.
I made my Workbench out of one.
Jennifer@Indy.USA
>...be careful when cutting it though. There are many large nails driven at odd angles to hold it together and all randomly placed. They will tear up a good circ saw blade in a jiffy. Removing the thick plastic poly finish off the top was a bear too, but worth it. It made great bench.
Jen
JohnKJordan in East TN
>I have a work bench made from a piece of bowling alley although mine is longer but narrower than yours - it still has the plastic disks where the pins went. It makes a wonderful workench top. I'm sure you could sell it if you didn't want to use it.
I was going to warn you about the nails, but I see someone already did.
Bench question about size
Mark_in_Michigan
>My first thought was a bench as well, but the small size of 40" x 44" doesn't seem like it would work well, all the benches I see are much longer. Since I don't currently have a bench and use things like my table saw and RAS as tables, do you think it would work?
Family Handyman this month has plans for a workbench that uses stock cabinets and a solid core door for the top. I like the size and storage of this much better than 40" x 44".
When I first got it 10 years ago I tore off the outer strips because they were chewed up badly. I found some nails and the metal rods going through it then. I found some more when I was belt sanding the other day. They truly are everywhere.
Thanks.
Re: Bench question about size
>>...the small size of 40" x 44" doesn't seem like it would work well
>...use things like my table saw and RAS as tables, do you think it would work?
Mark,
If it were me, even a short workbench would help, especially if it was the height of one of the saw tables. I can't imagine having too many surfaces, unless floor space was tight. I have one to the left of my RAS and it's great for supporting long pieces and pounding on things. (Hate to pound on saw tables.) I actually have the surface a few inches lower than the saw table and I lay down a couple of blocks when I need extra support (so I don't have to clean it off completely before use with the saw!)
You could easily knock together a couple of saw horses to temporarily support it and see if you like it. I have mine resting on top of an old kitchen cabinet base which gives doors and drawers.
>I had a 6' x 28" workbench, but had to cut it down to about 5' and might have to cut it down to 4'. As much as I liked the larger workbench, I just can't fit these things into my shrinking garage workshop.
Happy Woodworking!
Dale Warder
>Several people have responded with a suggestion to make a workbench from the bowling alley. I have such a bench. While it has served me for many years, I do not like the bowling aley surface. It is almost impossible to keep flat. The bowling alley is made from hardwood machined with a slight tennon centered on one side and a corresponding groove on the other. These pieces are assembled on edge and nailed together without glue. In constant use, the top shifts slightly and will not remain flat. I have mostly solved this problem by building a frame under the top with cross members and bolted the top to this structure with lag bolts. This is the only way I have been able to keep it anywhere near flat. If I was building another bench, I would pass on the bowling alley top.
Dale in SC
Mark_in_Michigan
>Mine has the grooves & tenons of which you speak, but I thought they were glued as well as nailed, I guess not. It was a very unlevel surface when I was belt sanding it and with the very hard wood, I am not sure I can ever get it perfect. I thought it was probably flat enough for the work I do, but if it will keep moving that probably isn't good. If I were to make a table and finish/seal both sides it would probably be OK right? (assuming the support structure is adequate)
