Questions for veneering experts
Sue McLam in Orange, VT
>I have the opportunity to bid on a veneered dining room extension table. From looking over the internet I've found a few places where I can buy veneer but wanted to find out if any of you have favorite places. It has to be a place where I could get either figured ash or birch (karelian). And I need 54"+ lengths.
Also I've seen some places don't sell raw veneer, but instead sell paper-backed, phenolic, 3-ply and "bubble-free" veneer. I'd like to get your opinions on these. I've read what they're for basically, but there's not enough info there to make up my mind.
One other question - I read somewhere that suggested that there are companies out there that will create your veneer pattern for you and then all you have to do is glue it to your substrate. I'd like to investigate that a little more as I'll need a sunburst pattern for this table and don't know how much I really want to get into veneering. It might be worth it for me to pay someone else to do it. Do any of you know of or have experience with companies that do this?
At this point I'll have to outsource the gluing of the veneer to the substrate unless I invest in the equipment. But that's not an issue right now as there are some places local to me that would do that.
So if anyone would like to throw in their $.02, I'd appreciate it.
Sue
Re: Questions for veneering experts
Thomas S Stockton
>Sue,
Stay away from the paper backed veneers, they are real thin and not the same quality as raw veneers. Two good sources I use are Certainlywood and Berkshire veneers both sell raw veneers and I think both are on woodfinder. Lenghts of 54" shouldn't be a problem, the most common lengths are over 8' except in burls.
You should be able to find someone who can do all the work for you, from jointing the veneers or creating a pattern to gluing it down to a substrate.
Tom
Lee Grindinger
Sounds a bit ambitious *LINK*
Lee Grindinger
>Sue, veneering is a craft all it's own. Cutting, matching, taping and gluing veneer can be tricky, especially a star burst pattern. If you know shops in your area with a vacuum press would it be possible for them to piece the veneers together and glue it for you?
I've done star burst patterns and it's tough to get them really right. It takes at least 14 consecutive pieces of figured veneer with little pattern drift between the first and last piece. Because all the pieces are so close at the center pattern drift shows as do slight mistakes in matching.
In other words, there is a definite and necessary learning curve to veneer work and a star burst pattern is not a good place to approach this curve.
To answer your specific questions; Don't use membrane backed veneers, as stated already they are very thin. Standard veneers are 1/40" and these are a good balance between workability and durability.
Use a vacuum press. I'd hate to lay up a star burst pattern with a hammer, they are even a bit exciting in a press. Once the moisture hits the veneer the outer perimeter immediately grows and makes wrinkling a real issue. I think veneering is a great skill and a fabulous tool to have in your box but this might be a bit ambitious for your first veneering project. Smaller stuff with easier patterns would be the place to start.
Kim Graves did a thumbnail description of a star burst pattern in the articles section here at WoodCentral but it leaves out a lot of very important things necessary to do it right. I'm including a link to a page I set up for a client showing the construction of their table, it's a star burst pattern made more complex by the lazy susan in the center it will give you an idea of the work involved.
Lee
A Starburst Table of Mahogany
Re: Sounds a bit ambitious
>Tom and Lee,
Thanks for your input. Lee, I'll try to find someone local to do the entire veneer thing for me. You scared me out of wanting to try! I really didn't want to do it anyway especially if it might turn into a one-time only thing.
Sue
Lee Grindinger
Veneering
Lee Grindinger
>Sue, veneering is something you may want to add to your design tool box some time in the future. It will require an investment of both money and time but it will change the way you design and build furniture. I think it wise that you not make that investment in a hurry and with a deadline but I'd hate to think I scared you away from doing it when the time is right. I think not.
Lee
Lee, you didn't :)
>Lee,
Don't worry, you didn't scare me away totally. I just think for this application I shouldn't believe that I could accomplish it after reading your very honest opinion. When I decide to undertake some veneering like that I will do it on a test project for sure. There was a part of me that said "how hard could it be to cut pieces for a sunburst and tape them up to give to someone to vacuum press for me?" And thanks to you now I know how hard it can be!
So, sincerely, thank you for your input.
Sue
