Veritas - Innovation in Tools
My new cyclone separator lid design *LINK*
Phil Thien
>I've been working on this for some time: A cyclone separator lid that approaches true cyclones in separation efficiency and is scrub-proof.
http://www.cgallery.com/jpthien/cy.htm
New cyclone lid design
Re: My new cyclone separator lid design *LINK*
I have a question
Robert R Clough - Thorncraft
>Phil
I am deliberately using this forum rather than your "internal" forum as my question may be of interest to others here.
I use the cyclone system but it is the small pail size. As an amateur who doesn't run the shop every day, at least not the sawdust making machinery, this seems to be all I need. So, how will this work with this size? It appears reasonably straightforward to build, but your lid will cut down on the available space inside. Should I go to a larger size can?
Robert
Re: I have a question
Phil Thien
>Hi Robert. The baffle reduces the capacity of my 10-gallon steel garbage can by approx. 2.5 gallons. If you can live with approx. 7 gallons of capacity (quite a bit for the average part-time home woodworker), I'd say to just use the 10-gallon can. Otherwise it can be ramped up, but there is a limit (we need enough CFM to enduce full rotation and therefor adequate separation).
