SURVEY - Cutting Dadoes With a Router *LINK*
David Yoho
>I could use your help with something I'm working on. For those of you that cut dadoes across wood parts or panels using a router, what method or jigs do you use? Specifically, what I'm interested in is how you locate where the cut lines up with your layout line for the cut. Feel free to go into as much detail as you think necessary about your method.
For many years I've been using the method described in Shop Shot #400 (link below). Recently I came across a much simpler idea (jig) that takes much less time to setup and is absolutely dead on accurate. The problem is - nobody makes a router bit like this method requires when cutting dadoes for the odd sizes of veneered plywood.
There are any number of gadgets and gizmos on the market that facilitate cutting these but they cost more than I'm willing to spend and my current method is more cost effective. The problem with my method and many others is setup time and accuracy.
I'm presently in contact with several router bit manufacturers to see if there is any interest in coming up with a modification to bits they all already make that, in conjunction with a very simple shop-made jig, would take the hassle out of setting up and cutting accurate dadoes for various sizes of veneered plywood.
It would be helpful to know what you use to accomplish this task with the router.
Thank you,
David
Shop Shot #400
Re: SURVEY - Cutting Dadoes With a Router *LINK*
NickB
>I favor the homemade t-square method. You make a T-square out of your favorite stable stock, where the cross piece of the t-square is flush with the workpiece and long enough to be cut by the router when you make your first (test) cut. For any further cuts, just line up the cut in the cross-piece of the t-square. You just have to make very sure your t-square is really square, but otherwise, it works for me.
Hope this helps,
Nick
>I built a jig similar to one described in one of the router books - two pieces of 1/4" (or thereabout) plywood with two pieces of hardwood (maple) on top of them. My plunge router slides between them. These are supported on the ends by two pieces of hardwood (~ 7/8" thick). The "slides" are about 30" apart. I first used this with a 1/2" bit - so if I pencil in some marks at 1/4" above my intended line, I can just line it up and clamp the jig and the piece to my workbench. I then use the router.
>Most of the grooving and dadoeing I do is either nominal 1/2" or 3/4", but it doesn't matter as long as the bit is less than the groove. I mark the groove on the target piece with one edge as a register, then set a fence to route to that line. I use the mating piece to mark the boundary line of the groove, then move the fence down enough to cut to that line. It sounds (an is) a bit cumbersome, but works well given the variability in the thickness of the mating pieces. I do the work on the benchtop with hold-downs and either a board fence that has a true shot face or a piece of 1" angle iron.
I don't do production work, so I don't think I'd be interested in a dedicated jig or set-up to do the same thing.
Clint
R. Lance in GR, Michigan
>David...I'm afraid I'll have to describe this instead of a simple picture as I'm computer challenged...I've made two guides (like a guide for a skilsaw to cut a straight line) out of 1/4" baltic birch...a wide base piece about 24" long and a second straight piece about 3" wide that becomes the fence that is glued to the base and then the router is used with a 3/8" straight bit to trim the wide base parallel to the fence...in laying out the dado, I measure and mark out the top of the dado and then clamp one of the guides on that line...and then pieces of scrap from the "shelf" are butted up to the clamped guide and the second guide is placed against this scrap and also clamped...with the scrap removed, you now have the guides ready for routing with the original router and 3/8" bit at the perfect dado width...with the two guides placed this way the router is supported level to the work piece riding on the two guide bases between the two fences...picture is worth a lot of words, hope I got the idea across.
Roger
>David,
I use the DadoWiz, no affiliation just a happy user. The following is an excerpt taken from the users guide:
The Dadowiz� is a precision jig for making matching dado cuts with a router in standard or out-of-specification
lumber. It eliminates the tedious steps involved in making precision dados without measuring the matching
material or adjusting the cutters through the use of shims or other techniques.
The Dadowiz� is designed to work with any hand held router equipped with a 1" outside diameter bushing guide. A Porter-Cable compatible bushing is supplied with the unit.
Roger
Ray Thompson - Middletown,IN
>Think of a T-square with a fence on top made of 1" aluminum angle. The router rides on top of the T-square against the angle. The 1/2" bit cuts the T-square parallel to the angle. Then another piece opposite the T-square with a 1" aluminum angle mounted that is adjustable to the first T-square arm. Start by putting the shelf between the arms and setting them snug to the shelf. The router rides between the angle fences and cuts an exact match to the piece that will reside in the dado. Takes far longer to describe than to set up and run the dadoes. I can have the dadoes done before I can get out the dado set and get it set up.
Ray
albertabob
>I now use Dadowiz.
I've used many set ups with equal results but none as quick as Dadowiz.
It's pricey but accurate and doesn't care about stock thickness.
Time is money.
Bob
Garrett in Victoria
>Hi David
Are you looking for straight router bits for the actual thicknesses of nominal plywood?
If so, I bought just such a set from Busy Bee Tools in Canada, and it inexpensive. Couldn't fine it on their website, but if you'd like, I'd be glad to phone them for details.
Cheers, Garrett
DadoWiz
David Yoho
>I knew that sounded familiar - I've actually got one buried in a drawer in my router table cabinet. Looked good when it was demonstrated but I just never used it because my regular way was easy, comfortable, and didn't require me to remember how to set things up!
I might give it a try if things don't work out with the other idea I'm working on.
Thanks,
David
Plywood Bits
David Yoho
>No, I have a good supply of these bits in all sizes. What I am looking for (and what I'm wanting to see if the router bit manufacturers can do) is a way to effectively turn these straight bits into pattern bits.
I haven't checked all the manufacturers but two, Infinity and Whiteside, make down-shear straight bits for plywood. All they need now is to add a top bearing and stop collar and they'd have pattern bits. I don't think it's as simple as just adding the bearing and collar to an existing bit because that would reduce the amount of the shank that would be available to go into the router collet. I also think these bits could only come with 1/4" shanks so there would be enough diameter to get bearings that would work due to the bit diameters.
We'll see. I have a few feelers out and I'm waiting for their response.
David
Thanks - here's the story
David Yoho
>Thanks to all who responded.
My idea is to try to make routing dadoes for plywood easy, accurate, inexpensive, and quick.
As I said in another response, I remembered actually having the DadoWiz stashed away unused. It seemed like a good idea at the time but I just didn't have time when I brought it home to figure out how to use it, so it got stored and forgotten.
I'm not thinking the manufacturers are going to be chomping at the bit (no pun intended) to come up with what I'm asking for if it will cut into their sales of these gizmos like the DadoWiz. Infinity Tools just started selling a similar gadget for $129.
I saw a jig Glen Huey uses that, combined with a pattern bit (or the bits I'm looking for), make cutting dadoes for plywood easy as falling off a log. All you need to make is a piece of plywood about six inches wide with one straight edge and attach a wood cleat on one end set at 90-degrees to the plywood. Armed with a straight bit in your router set to the required depth of cut, you set the jig flush with your layout line for the dado (the wood cleat on the bottom front of the jig butts up to the edge of your work piece and squares the jig), clamp it to the work piece, set the router on top and cut.
A plywood straight bit setup with a top bearing the same size as the OD of the plywood bit would effectively become a pattern bit. The bearing would ride along the edge of the plywood jig, thus cutting your dado exactly where you wanted it. If you had a series of dadoes to cut, you simply move the jig and router to the next one, clamp the jig, and cut. Presto! No setup time, no complicated jigs required, no big expense, no remembering how that fancy gadget you bought works or how to adjust it for a different size dado, and it cuts exactly where you want!!
Even if you're not a production shop, you'd have to like this for its ease of use, flexibility (could make several jigs of various lengths), cost, accuracy, and best of all, speed. I've got some feelers out there, so I'll see what happens. Who knows, maybe someone will see this as an opportunity and add this idea to their line of bits!
David
Re: Thanks - here's the story
>David, I have read your description over and over. What I think I am seeing is a wooden (plywood) straight edge/square. With this home made straightedge, you clamp it right beside the line where you want the dado and then use a patterning bit? Is it really as simple as that? The pattern bit must be the correct size for the dado, but other than that you just cut a dado? If you wanted the dado to be 3/4" and you had the bit, accurately cobble together a couple of scraps and you are in business?
If I got that right, I see a couple of minor problems. The router would be running on top of the straight edge and only fifty percent supported. For me, it would tend to tip. The edge would tend to wear over time and would become somewhat wavy. If the guide only got a little use or you made it out of tough wear resistant material it would work better.
I am thinking of making a fixture that involve two straight edges opposing each other. The base piece would be thin, an 1/8 or 1/4" and there would be a straight edge for the base of the router to run against. Attach the straight edge to the base piece and use the router with your favorite bit to trim the base piece parallel to the straight edge. Attach these opposite each other with a couple of slotted sliders, on on each end. You insert a piece of the shelf stock between the two guides and and clamp them with the sliders. Now you can actually see the width of your slot and position it right to the line, or you could attach a Tee piece underneath if you want. Just clamp it in place and run the router down both sides and you are done. I am not claiming this as my idea, I saw it somewhere and wish I could remember who to give credit to. I also think that others above have mentioned the same thing, but we all use different words.
As I see this, there are some advantages. It uses a standard bit, cheap, easy to replace, and once the shoes are cut, as long as you use the same diameter bit, you can keep going. You don't have to find the perfect bit with the correct guide bearing. (A problem trying to find the correct bit is that the plywood is not consistent anymore.)
Another advantage is that you could make one of these set up for a 1/4" or smaller bit and as far as I know nobody can make a pattern bit that small.
Also, the router is "captive" between the two guides and can't wander off as it would for me if I were using a straight edge. And because there is a guide or shoe on both sides it would not be prone to tip.
I'd like to see a picture of what you are proposing. I am wondering if it is better that my adopted idea.
Re: DadoWiz
Roger
>David,
I would suggest that you break out the DadoWiz and try it. The set up time can't be more than 30 seconds, how fast do you want?
Roger
Jim Dillon
>David,
I use the same setup as Nick. A simple t-square with the long arm about 24 inches and the short arm about 8 inches (guessing here as I am not near my shop right now). I then mke this one-time modification to the short arm. With the router in place along with the base I intend to use, I drill/cut an oversize hole (say 1 x 1 inch) right where the router bit is. I then brad nail a wooden disposable edge to the short arm. I rout thrugh the edge with the router bit I intend to use. Then I place the t-square on the workpiece, line up the routed edge with the pencil mark on the work piece, adjust the depth and let her rip. I use the same approach for dovetails in wide pieces. One must be sure to keep the same edge of the router base against the T-square edge. Works for me. Here is a crude pic; sorry I didn't have an actual pic.
Jim
How about a video
David Yoho
>Barry, I just watched this video again and admit I must not have paid very close attention to the part at the end. I think the jigs Glen shows after the square platform jig might be like what others are referring to but certainly would do what I'm looking for, but longer versions.
Anyway, this should show you exactly what I was talking about. Still, I'd like to be about to use pattern bits sized for plywood with this jig. It's just too simple!
David
Here's the link *LINK*
David Yoho
>Sorry, don't know what happened to the link previously.
Huey's Square Platform Jig
Re: Here's the link
>David, Thanks for posting the link. Makes it much more clear. (If a picture is worth a 1000 words, what is a video worth?)
I was describing the second version. If the base of the jig is thinner, you could use a shorter router bit and have less whip, but I don't think that matters much now that I think about it. In both cases there is the wear issue with the surface that either the bearing rides on or the the shoe of the router rubs against. I have made several patterns that wore out prematurely and have to remind myself to use material suitable for the number of cycles.
You could convert both of Glen's jig to the one I am talking about by making a "right" side for them. Just make a matching guide and attach it with a couple of sliders. Then just insert the self between the two and lock down the right side. One pass out on the left and one back on the right and your dado is done. And, putting a right side on the jig solve the "tippy" problem too. You could remove the right side when you don't need it.
I just realized why Glen laminated the two pieces together on the jig. It must be "tall" enough to allow for the full height of the bit and bearing. (A Duh! moment now that I under stand.)
Worth 1000 words
David Yoho
>I figured that video would help clear things up.
In both cases there is the wear issue with the surface that either the bearing rides on or the shoe of the router rubs against.
I don't anticipate a problem with wear. I would think for the 1/4-inch material a good choice would be tempered hardboard. After all, the bearing in all that touches the edge, which shouldn't create much wear. As far as the top surface the router base comes into contact with, a thin coat of wax might help but I don't think there would be enough everyday use to create a wear problem. Also, because of the relatively low cost to produce these jigs, if they do wear sooner than expected, it's a simple matter to make new ones!
A single pass is even faster! Speed of setup and cutting are my main criteria.
And, putting a right side on the jig solves the "tippy" problem too.
This won't be an issue for me. Like in the video, I use a "D" handled (PC) router. Downward pressure on the left handhold combined by the router's tendency to move toward the jig "fence" will keep things from tipping to the right.
Even after making these jigs for the various bits I use, if someone comes out with pattern bits sized for plywood, I'll be all over them!
David
Johanna
>I use two L-shaped guides clamped to the work piece.
The part of the guide that rests on top is 1/4" hardboard. It is attached to a 3/4" piece of MDF. When I attach them, I put a screw in the center of the overlap area so I can adjust the angle to a perfect 90 degrees before I staple or nail them permanently.
I put the router on the workpiece so that it is exactly in the right place for the dado, then clamp the guides so that they trap the router on either side. The advantage of this system is that if you hit a place where the wood is squirrely, the router cannot shift off the cut line.
Thanks
>Thanks David, I don't get as much mileage out of my router as I should and not nearly as much as some people. I think it is a powerful and versatile tool and I should give more use. Sometimes I ever think the jigs and fixtures. Many times simple ones will do and the job gets done well. I also tend to make jigs that are slapped together out of scraps and then throw them away when the specific job is over. I need to make some more general use jigs. And you are right about the wear problem. Hardboard and Baltic birch type plywood make good wear surfaces.
