Mostly OT: Chimney cleaning
Ken Platt (Granby, CT)
>Folks -
I've generally opted to have a guy come out and clean my chimney for me, since the rather heavy fireplace insert (Vermont Casting Winterwarm) needs to be pulled out to get at the bottom of the flue. However, this year for whatever reason my usual chimney guy is blowing me off, so (being a born-to-DIY-type) I'm wondering if I can do this myself, hopefully without pulling the insert.
Has anyone worked out a decent way to do the cleaning from the top? I'm picturing some sort of little tray for underneath the brush which catches most of the scrapings. Then, maybe I could attach some sort of smallish diamenter, very flexible tube to the shop vac and snake it up the insert's damper opening to get the stuff that falls into the short tube that runs from the insert's top up into the bottom of the flue.
I can also run the shop vac hose down from the top, but I'd have to kludge together a longer length (maybe 12 feet) and I'm not sure the shop vac would be effective with that length of hose. Anyone had any success with this?
Anyone out there worked this problem out? BTW, the flue is only in need of a light scraping; there's just a thin layer of peeling stuff, looks like peeling paint. Thanks -
Ken
