Re: New tools vs old
wilbur
>Hi Basil,
I asked exactly this question several months back, when I was trying to decide between a new or used bandsaw. There are some things about the old machinery that current machines can't compete with -- it's just that these are things that don't show up in spec sheets.
This is what I learned after seeing 1940-50's bandsaws up close.
Many parts on the older bandsaws are made to greater thicknesses than current bandsaws. This is not something that will necessarily show up in a spec sheet. For example, a spec sheet will say that the table is, say, 14" x 14" in the case of the Grizzly 0555, but it won't show you that a 1940's bandsaw table will be a heavier duty casting, resulting in a thicker and more reinforced table than the Grizzly. Likewise, in the old bandsaws, the sheet metal used for the bandsaw wheel covers and stand will be thicker, you'll have beefier trunnions on the table, the casting for the frame will be thicker and better reinforced, and in some cases you'll get cast iron bandsaw wheels instead of an aluminum one, and so on. All of this added mass helps to improve the smoothness of the bandsaw when it is running.
As far as the motor goes, there's something about an older motor that seems to make it run better than newer ones of the same HP. My bandsaw motor is only 1/2 HP, but it can do pretty good work, as I'll get to in a bit.
Some of the other extras you point out may not be completely necessary. I don't know how much experience you have with a bandsaw, but when I was shopping for one, I had almost none, and was worried about finding a fence, miter gauge, and ball bearing guides as well if I was to get an older machine. Guess what happened. I've been able to saw 3/32" thick veneers from domestic hardwoods freehand, thanks to a good blade. No fence, and no ball bearing guides. Also, I only have a 1/2 HP motor on my bandsaw.
Whether you get a new bandsaw or old, I'd see what you can do without those items before putting them to use.
As far as the downsides to going with a used older piece of machinery, if you need service, you're going to be pretty much on your own. If you find an old Delta, many of the parts are still available, although they may take some hunting to find them. However, it really doesn't take that much mechanical know-how to get one of these things running. I managed to do that with my bandsaw and lathe, both of which date back to the 1940's, and I'm no mechanical genius. In fact, my day job is being a pediatrician, and my lathe required a teardown of the headstock and spindle, while my bandsaw required disassembly of the lower wheel and axle, and I lived to tell about it.
Finally, if you find a good condition used Delta bandsaw and decide it isn't for you, you'll be able to sell it for pretty much what you paid for it. This won't be the case with buying a new Grizzly or Rikon.
As for me, I started off convinced that I was going to get either a new Delta X5 14" bandsaw or maybe the Powermatic 14", and ended up finding a 16" Walker-Turner bandsaw instead for much less than either of the first two. I just love this thing. I had to do some work to get it into top shape, but I'm very happy that I did.
The best thing to do is to find someone that has a older piece of machinery and look at it up close to see what I'm talking about. In the meantime, my 2 cents would be that if you see an older Delta bandsaw in good shape for $400, go for it.
Hope this helps!
