Three ways to do it
A.J. Hamler
>Barry...
Yep, pretty much like planing small pieces, you can do one of three things:
1) make a sled for them
2) temporarily attach longer "runners" on the sides. These can be hot-glued or even regular-glued, and then cut off later
3) You can also feed them through in tandem, with the trailing end of the previous piece butted up firmly to the leading end of the next piece. That way the rollers will always have something under them; the sander can't tell the difference between a long board and several short ones butted up against each other.
A.J.
