Basic table saw ripping question
Dan Mitchell
>I was just watching an early New Yankee, episode 309, "Library Table". Norm is ripping a ~1" wide piece from a 48" x 8" x 1" board. Looks like cherry, though if he mentioned this (or another species) I missed it. What strikes me as odd, is he's ripping the board such that the cut off 1" piece is between the blade & the fence (i.e., the fence is 1" from the blade). He's pushing the board forward by applying force to the larger, outer portion. I would think this would encourage pinching the blade & kickback. If I were doing this, I'd have the 1" section as the cut off piece on the left side of the blade, and would push the board forward using the section between the blade & the fence, probably using my Grr-Ripper. I've seen him do this before as well, in fact on the "safety intro." to this episode, he's ripping about a 1" piece from a board approximately 4" x 12", and again, he has the narrow bit next to the fence. This time, he is pushing the narrow bit with a push stick. Am I missing something?
Just trying to keep all my fingers ;-)
Dan
Re: Basic table saw ripping question
Your intuition is right
Denis Ch�nard, Orl�ans, Ont.
>The narrow part should be on the outside of the blade, not trapped between the fence and blade. Doing it the way Norm does has the advantage of being faster if you need to rip many pieces to the same width. But it's not as safe.
The most important part though, is that I hope that you, unlike Norm, use your blade guard and splitter...
DC
Re: Your intuition is right
Dan Mitchell
>That makes sense (he was cutting 2 pieces of equal width from the board). I'd rather reset the fence. I do use the blade guard whenever possible, one reason I selected a PM2000 as my most recent saw is the riving knife. Far be it from me to 2nd guess Norm (he with decades of experience AND all 10 digits), but ripping such a long board this way AND not using any type of splitter/antikickback pawls seems especially risky.
Thanks for the reply.
Dan
Lee Schierer - McKean, PA
>For pieces as wide as 1" where you can easily get a push stick past the blade, it isn't really unsafe to run the pieces between the fence and the blade. Narrower pieces that don't allow for a push stick to clear the blade have a good chance of coming back at you. Unless you are very good at setting your fence, getting identically wide pieces by resetting the fence can be a bit of trial and error. A super way to do this is to make a shooting board that is 5-6" wide and at least as long as the piece you are cutting and place that between the fence and the blade spacing off the width of the strip you want. Then you have the shooting board for support and control and the tab on the back side of it will feed the strip all the way through the cut. Each piece is identical and all can be cut safely. I've cut dozens of identical 1/4" strips using this method.
As always, if you don't feel safe doing something then don't do it that way. Saving time on one cut all goes down the drain if you have to make a trip to the ER.
Lee
Jesse Cloud
>I can see leaving a 1" offcut between the blade and the fence if you have a pushstick, but there's just no way I would ever rip without a splitter. You never know when that wood will get cranky and want to squeeze the blade.
Re: Your intuition is missing a bit of insight
Keith Newton
>While you can convince yourself that the more fear that you have for a tool will make it safer for you to use, if you don't ever understand what causes certain kinds of accidents, your fear may lead to other pitfalls.
A year or two ago, there was a video clip showing how feeding without a splitter or something could lead to a kickback. The demonstrator was standing totally to the right of the fence, and feeding a short piece about 8" wide, with the fence about 7" over, while only applying feeding force about one inch from the blade. Near the end of the cut, the piece rotated and climbed the back of the blade, then, as might be predicted, shot across the room.
While a splitter may keep this from happening, what is most missing is "That is not the way to feed a piece like that".
You should consider a number of things when ripping on a TS. First, if you are new to using a TS, you might consider feeding some stock over the table without even having the blade up, just to get the feel of the drag of the table, and keeping the work against the fence. If you feed something across the table, and only apply the forward feeding force along a line too near the fence, the wider the work gets, the more drag on the left hand side, which leads to a rotation in the CCW direction, and when you add the drag or resistance of the cutting action of the blade, this only compounds the problem. Rotation is not your friend when using a TS.
What you need to think about, and become sensitive to, is finding the right balance of force for feeding the work, against the drag of the blade and sliding across the table, and try to concentrate the CENTER OF EFFORT, over or in line with the CENTER OF RESISTANCE.
I usually think of this as being and imaginary line from the front of the blade to the back of the fence if it reaches the back of the saw table.
You should keep an eye on the front of the fence, and keep the work touching, but if you transfer your focus there, and ignore the back of the fence, there is a tendency to let the work rotate to the left, and once the back of the work gets away from the fence , it is hard to correct, so keep the focus on the back of the fence.
There are a lot of little tricks to learn to dance with your table saw, which is a lot more fun that fighting it.
Jay St. Peter - SoMD
>Well, I do it like Norm. I do use a splitter, but my overhead guard just gets in the way when ripping that thin. I actually push the whole piece, like Norm was doing, until the end of the cut where the piece on the fence side must be pushed. If you don't push the piece on the fence side, you leave it hanging just waiting to get you. I have magnets attached to my push stick and keep it stuck to the top of the fence. About the time the trailing edge of the piece being cut crosses the front edge of the table, I grab the push stick and finish the cut with it. Feels safe to me, but YMMV.
Jay
Dan Mitchell
>"A super way to do this is to make a shooting board that is 5-6" wide and at least as long as the piece you are cutting and place that between the fence and the blade spacing off the width of the strip you want. Then you have the shooting board for support and control and the tab on the back side of it will feed the strip all the way through the cut."
Lee - I'm having a bit of trouble visualizing this, can you elaborate a little?
Thanks,
Dan
That's the first part in the sequence leading to an accident...
Not wanting to pick on you, but not using a safety device because it's "inconvenient" should direct you to use another approach. Norm is NOT an example to follow when it comes to tablesaw safety...
DC
