>OK, I've finally had it with slow dial up internet connection. We live in the country, and dsl is not available. I'm curious if anyone has any experience with satellite internet? Specifically, I've checked Wild Blue and Hughesnet. Wild blue is a little cheaper, but advertised speed is a little slower. I know neither will compare with DSL, which I have at work. But my wife is about to start an online class, and I have 3 kids that use the net frequently for school, so it's time to do something. I would appreciate any feedback.
>I am delighted with Wild Blue. Of course my installer had done 2000 installations so it all went well. I think happiness depends greatly on the installer competence.
I was told that at least in my area Hughes fired all the independent installers recently. So, I would be wary of a Hughes installation unless I knew who was doing it. They could be new and inexperienced, or not?
>I don't have any direct experience with Satellite, but there have been a couple of threads here on Woodcentral about it in the not too distant past. A search should find them for you.
>I upgraded from a slow dial-up to Hughes Net and thought it was great for the first 5 to 6 months. The last month I had to reboot the system half a dozen or so times a day. After many calls to tech support I finally told them to cancel the service. I'm fighting with them about an early termination fee. When it was up it is great with about 1480 kps down. We did get DSL service in the area and I was able to switch to it but that was not the reason I stopped Hughes Net as I didn't know about it at the time.
>John, I also live where satellite is the only choice other than dialup. I have been using HughesNet for over a year now. In general very satisfied other than the cost. I had a series of problems about four or five months ago when I was having trouble with connections. After the ordeal of dealing with off shore customer service I was finally able to get to talk to someone in Atlanta and they sent a installer out, not the one who did the original installation but another installer. He found that the original installation had been done with some inferior connectors and replaced them. Things have been fine every since. As Bill Tindall has said the installer makes all of the difference in how satisfied you will be.
When I made my decision last year WildBlue was having problems. They may have solved those problems, I just don't know. There is a series of forums on satellite ISP's that can be informative. I don't have the UAL's readily available. If you can't find them let me know and I am sure that I can dig them up again.
There is one problem with satellite. That is there is a Fair Access Policy. That means that you are limited in how much you can download in a 24 hour period. In the year plus that I have had satellite I have had the problem once. That was when two granddaughters were here for a weekend and they were doing real time interactive activities.
If you are willing to accept the higher cost of satellite service I am sure that any problems with a satellite installation can be solved and you will certainly like the higher speeds.
There was a thread or two in the last couple of months about this if you want to check the archives. I used Direcway/Hughes for years for my work until I could get cable modem. I still have the equipment if you go that route and don't want to buy new.
>I'm not sure if something changed with the new page format, but I can't get anything to load during an archives search - it just "sits and spins" with no results shown. (And I'm on DSL at work, so I can't blame it on slow dial up!). I'll try to check later. 'Preciate the info though.
