? Furniture Wax, and TSP ?
Garrett in Victoria
>I applied a dozen or so coats of wipe-on poly to a project, lightly sanding at 400 between every third coat. I also sanded what I thought would be the final coat and then rubbed it out with rottenstone. As expected, I was left with very smooth, dull surface. However, what I did not expect was that the wax coat did not bring up a clear, satin sheen. I now want to remove the wax and lay on some more poly.
Will TSP get it all off?
TIA, Garrett
Re: ? Furniture Wax, and TSP ?
Something not right here, a recommendation
Bill Tindall, E.TN
>I typically put on 2 coats of gloss urethane, grind it flat with 360-or 400 wet/dry sand paper lubed with water and then rub out with rotten stone and oil. The result is a bright high gloss finish.
You used gloss urethane, right? Rubbed out with felt or equivalent pad lubed with mineral oil? Well, then the rotten stone must be coarser than what I use.
Unless you didn't use gloss urethane there is no need to remove what you have applied. Just need to figure out what went wrong in the rubbing.
BTW, Canadians can get Benjamin Moore "Clear Varnish, High Lustre (must be Canadian for luster) #407-00. I snagged some recently in Thunder Bay, ONT (nice folks at that store). It is bright, rock hard and rubs out wonderful. I had given up hope of ever finding just plain varnish when wife says, "ask them" as we passed by the store. To humor her I stopped and ate crow when they had just what I was looking for to finish the Chester Co chest.
Re: Something not right here, a recommendation
Garrett in Victoria
>Hi Bill
The wipe-on poly is Varathane satin, not gloss, since that's the sheen I need to end up with.
I used Behlen 'Master' rottenstone with water as lubricant - the instructions say oil or water - but I used very little water, not much more than a rather damp cloth, so perhaps that's the source of my problem. I'll try oil instead, but would like to re-coat in any event and start fresh.
So, will the TSP get rid of the wax? Can i apply the Benjamin Moore "Clear Varnish, High Lustre" over the cleaned and re-sanded poly?
And, Yes, in Canada words such as lustre, centre, colour, etc. maintain their original spellings.
Cheers, Garrett
your finish is upside down
Bill Tindall, E.TN
>The wipe-on poly is Varathane satin, not gloss, This is likely your problem. The dulling needs to be only on the surface, with bright lustre underneath. When rubbing out a finish always use gloss for the base coats. In fact it is best to always use gloss under any circumstances and only use less lustre on the last coat. With thick coats of delustered material under neath the finish will look dead.
I used Behlen 'Master' rottenstone with water as lubricant - the instructions say oil or water - but I used very little water, not much more than a rather damp cloth, so perhaps that's the source of my problem. I have never used water and I use a sea of oil, think soggy pad.
So, will the TSP get rid of the wax? Probably. May wipe with mineral spirits first.
Can i apply the Benjamin Moore "Clear Varnish, High Lustre" over the cleaned and re-sanded poly? I don't know. But, you will have a backwards situation. You want bright below and duller on top. It may still look dead.
Also, a wipe-on may not be hard enough to rub out. Ideally you should have brushed on two to three coats of some hard varnish, ground flat with fine wet/dry paper with water or oil lube, and then rubbed the brightness back. I have a dining table that looks high gloss after rotten stone rubbing. But the finish is very hard old fashioned moisture cured urethane. Ideally the finish should only barely dent with application of finger nail force.
Re: your finish is upside down
Garrett in Victoria
>Much obliged, Bill. I bought some oil for lubrication, and some Benjamin Moore varnish this afternoon. I'll sand down as close to the stain as I dare, then start over with the gloss. I'll report back in a few days.
Cheers, Garrett
Additionally...
David Yoho
>Just to expand on what Bill was saying - anytime you're going for a final finish other than gloss, it's best to begin with clear gloss on all applications all the way to the last one or two. At that point, apply the final sheen of choice.
Satin and semi-gloss have particles in the mixture that reflect light, thus providing the desired final effect. When you apply these as the sole finish, the look becomes unclear because of the reflective particle in each topcoat layer. The outcome is often "cloudy" or "plastic-looking". Starting with clear gloss until the last coat or two, yields a more clear looking final finish. The only thing to watch for is missed spots where the satin didn't cover the gloss. That's why I like two coats of satin over gloss.
David
Thomas S Stockton
>Garrett,
What you want to use to remove the wax is naptha that's what I always use.
Tom
