Re: Classic Hatteras boat Interiors
Garrett in Victoria
>Hi Ron
I own a new-ish 40' boat, and know first-hand what's involved in maintenance, etc., etc., so I admire your willingness to take on a project like this. I assume you know about boats, and more particularly, about what to look for when buying older ones.
As to your specific question, much depends on what Hatteras used as the original finish, and since these were factory built, my guess would be sprayed lacquer, but I don't know for sure. Another factor, of course, is the condition of both the original finish and the underlying wood. If good, a careful cleaning with a solution TSP (tri-sodium phosphate available at any hardware store - to remove mildew, mold, grease and wax followed by a very/very light sanding with 600 grit paper would be enough prep to lay on a coat of wax or oil. When buffed up it should look quite good.
However, if, as is likely on a boat that age, there's dry rot or water staining from window or hatch leaks, or a lot of scratches and dings that go beyond 'patina of use', the order of magnitude of the work required rises exponentially. Unless someone else can tell you with assurance what the original finish is, you'll have to experiment in an area that is not too obvious, and apply small patches of whatever it is you want to use to see whether it will adhere and provide the outcome you are looking for.
Two useful websites to ask these questions on are:
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
and
http://www.passagemaker.com/
Cheers, Garrett
