Re-Finishing Question
Tom Norton
>I have 2 spot on some table tops that have a whiteish cloudy spot. I see that Woodcraft sells a product from Liberon called Ring Remover.
Does anyone have a home brew recipe?
Re: Re-Finishing Question
Bill White
>On some finishes (no poly) such as varnish,lacquer, and shellac I have used mayonnaise. DON'T LAUGH DANGIT!!!
Bill
Damp, but not wet
David Yoho
>As per Michael Dresdner -
Dampen a cloth with denatured alcohol and wipe the area once or twice with it. The white marks will come out immediately. Repeat if necessary to get them all the way out. The cloth should be damp, but not wet, which means "about as wet as a healthy dog's nose." This method is also safe for shellac, due to the limited amount of alcohol being used.
This always works for me.
David
