Veritas - Innovation in Tools
Shop heat
Shop heat
Shop heat
Dan Mitchell
>I would like to add some heat to my shop. The space is in a 2 1/2 car garage, with one parking space occupied, total volume ~5040 cu' (30' x 21' x 8'). It is uninsulated, though there is drywall, and it has living space above, which is at the moment unheated. There is an electric (resistance) forced air furnace in the shop area, which provides heat to the (again, currently unheated) living area above. I have considered simply adding air inlets & outlets to this existing furnace, blocking off the living space it is now set up to heat, probably the cheapest approach, but I am a bit leery of drawing shop dust into this system. I'm wondering what alternatives exist, like a portable kerosene or propane heater, though I no nothing about these, especially venting requirements, etc. We are in the Seattle area, so it doesn't get TOOOOOO cold, and I'm pretty tolerant of the cold, so around about 55-60 would be enough. Just enough to take the edge off ;-) Any suggestions appreciated.
TIA!
Dan
Re: Shop heat
Re: Shop heat
JohnKJordan in East TN
>Dan,
In addtion to what may get posted here, check out the thread in the Turning messageboard on shop heating.
Re: Shop heat
Re: Shop heat
Patrick Jaromin
>I hung a 240v electric heater in my 2 car garage shop. It cost ~$250. Last winter I maintained nearly 70 degrees for over a week during the finish process on a large bar and while I didn't try to track electric costs, my bill (surprising to me) didn't increase noticeably.
The heater did a great job of "taking the edge off," typically in relatively short order (30min or less) even on some fairly frigid days that we get every so often (read: 6mos. of the year) in the Chicago suburbs.
I've included a link to one that looks like the one I installed...though I know I paid $100 less than this at a local home center.
As for ventilation -- I just put a dedicated shop addition on the house and while there were some questions raised by the inspectors, they ultimately agreed to allow heating supply without return in the shop due to the dust issue. The fact that I had double doors in the front and a 300CFM vent fan helped make that case.
Re: Shop heat
Re: Shop heat
Bill White
>I use the oil filled radiator elec. heater for my shop. 9 foot ceilings and well insulated. Toasty as I want it to be, and no dust-in-the-return issues.
Bill
Re: Shop heat
I'm like'n this whole . . .
Steve Mackay
>radiant heater thing ! Covers MUCH more area than Mr. Lee told me it would, costs less and I'm not heating the whole space ( the air ). If I had a bigger space I could see only one at each end keeping everything toasty. Also makes insulation a moot point.
Re: Shop heat
Patrick - NO LINK!
Dan Mitchell
>I'd like to check out the heater you mentioned, can you post the link?
Thanks!
Dan
Re: Shop heat
Re: Shop heat
Dan Mitchell
>Thanks John, some good ideas in that discussion! I never would have seen it w/o your tip.
Dan
Re: Shop heat
Re: Shop heat
Dan Mitchell
>I'm sure the "well insulated" part helps! This space has unheated living space above, which at any rate should be better than an uninsulated roof. One side wall is a 3rd car bay with a doorway, so again with the door closed (once I put one up!) that ought to be fairly decent. Then there's 2 wooden single car garage doors, pretty well gasketed, no windows, can't do toooo much more with them barring major expense, then the back wall has 2 72" x 48" double pane windows. Great for natural light, at least. I'm thinking of renting one of those blown in insulation machines to add insulation to that rear wall & the remaining side.
Thanks everyone for the replies.
Dan
