There are several approaches to rust prevention.
Forrest Addy
Lower temperature AND humidity.
Surface passivation
Barrier coatings
Active corrosion inhibitors
Sacrificial metals (zinc galvanizing
Prevention of condensaton.
Lower local enviromental temperature AND humidity may be energy intensive because it involves AC or at least dehumidification. This is the most comfortable and intrusive to the home shop worker. If the shop area is sealed up and a mechanical refrigeration dehumidifier employed rust on power tools can be made a dim memory. Dessicant wirk only so long as they are recharged and replentished as needed. Their most practical use is when the machine is stored in a heat welded 100% sealed envelope. Their application in an open shop is all but futile. You need dessicant container big as hay bales to make a dent in the humidity profile of the average home garage workshop.
Surface passivation is not a viable option for the home shop and it doesn't have lasting effect on cast iron. Briefly it involves a chemical treatment that renders the metal surface to a Ph that prevents oxygen. When chemically cleaned iron castings are dunked in a hot caustic at the very end and dried quickly they may not rust for weeks. Can't do that with an assembled table saw.
Barrier coatings like waxes, oils, and preservatives have varying effect. Most general purpose waxes are nearly useless for preventing rust in a humid environment particularly in a marine coastal climate. Oils can be very effective and preventing rust but are not welcome on woodworking machinery table because it has to be cleaned off before the machine can be used. Preservative come in several guises, some more effective than others. A home shop owner should experiment to see what works best for his environment.
Active corrosion inhibitors like vapor phase impregnated paper works only if the machine is sealed off in an impervious envelope. The inhibitor goodies soon disperse in open air and the peper they were once impregnated in beccomes just paper.
Sacrificial metals (zinc galvanizing) not practical in the home shop. Neither is cathodinc protection suggested by the article referred to in the original post - but there may be some wrinkle.
Prevention of condensaton on the machinery not in active use is simply sccomplished by slightly warming from underneath and covering with a breathable fabric like an old blanket. Condensation and consequent corrosion can all but be prevented. You do have to remove the covers and the heaters etc when you want to work but this is a small price.
Boeshield is popular but it doesn't last very long in the Pacific Northwest so I don't use it. I use to use dehumidifiers but I had trouble with them icing up in cool weather. Now I blanket my machinery and use gentle heat from a light bulb. With the overhead lights off my shop looks like an elve's village. Works good and it's simple.
If I have to store a machine for some time I spray all bare metal with LPS3. While its a minor pain to remove it's very effective and works for years in open shelter.
What works for your particular climate and shop conditions is variable. A Montanan in a drafty home shop has little problem with rust and can get by with wax alone all winter but someone on the east coast of Florida has to resort to heroic efforts to contol rust from day to day.
