Making walnut Sap wood whiter Questions.
>I have a NE bowl I turned from green walnut. The sapwood is sort of murky ugly dirty brown. (Did I say "unattractive" clearly enough?)
It is now dry. Is there some way to go one way or the other and turn it brown or make it cleaner white?
Re: Making walnut Sap wood whiter Questions.
Dale Stansbery
>I doubt that you can do anything to whiten it so it looks "natural". What I've found is that cutting walnut in the winter is the best way to get the whitest sap wood. Then you'd have to get it dried before the browning takes place, if that's even possible. Walnut that I've cut in warm weather rapidly starts the sap wood discoloration process.
easy to turn brown
Bill Tindall, E.TN
>Read article on steaming walnut in Articles section- to summarize put in pressure cooker and heat briefly to over boiling point of water.
