Adding Dust Port on Bandsaw
Ray Binnicker
>I have a 14" Delta bandsaw with a riser block. It is about 15 years old and I wouldn't trade it for anything. It is a great machine, except for the worthless dust collection port under the table. Is it possible to add another port, say in the bottom door? If I could somehow add a 2-3" port there and tie it in to the one under the table surely it would do a better job of sucking the dust out. Has anyone done this, and if so, please get me started.
Thanks
Ray Binnicker
Re: Adding Dust Port on Bandsaw
>A friend of mine put one in the back of his bottom down near the front of the wheel. Used a hole saw. Seemed to work okay.
>Ray I have a Delta bandsaw with a riser. I cut a hole through the door at the bottom and made a dust port. Later I found out Delta makes a dust port for the saw that fits on the side where that goofy little chute is. Iturra carries it. It allows for a four inch pickup hose. I made one similar to it. Used an end boot for four inch duct and mounted it with an eyebolt that hooks over the bolt the original port used.
I did not like the port through the door. It made the door "self closing" as if it were spring loaded. If you do it that way, be sure it does not interfere with opening the door to change the blade.
Easy and Effective
>Good Evening Ray,
I have a Jet 14" saw with riser block and installed a 4" port in the bottom door. I also installed one in the 14" Jet bandsaw in my #3 son's shop. I used sheet metal screws thru the plastic flange of the standard DC 4" ports, and sealed with silicone caulk. Its a fairly large flange, and I positioned it as close to the front of the door as I could so as to felicitate dust pickup beneath and closest to the lower blade guides. It is extremely effective. I get only a little residual dust inside the doors, and absolutely NO buildup anywhere.
I wrestled with the idea of cutting into the door of my saw for a couple years. In the end, I am very glad I did. I also plugged the 2 1/2" proboscis which came with the saw. It was worthless for DC purposes. Someday I will remove it entirely and fiberglass it over. It is an easy fix and shouldn't take too much time at all.
George
Ron Hildreth
>Ray,
Thought I had a website bookmarked that covered that in what I thought was rather a unique way. This guy had used a 4" toilet floor flange, and mounted it to the bottom door of his band saw. Worked great, and with a little black spray paint, looked manufactured. Wish I could find that web site, as there was photos and step by step instructions.
I'll keep looking, and if I find it, I'll post the link! Sheesh-Hope I sleep tonight!!
Ron in Iowa
Ray Binnicker
>Thanks guys ! You've talked me into it. I've put it off long enough. I'm going tomorrow and get one of those metal cutting hole saws and a flange. I'll let you know how it turns out. It has to help though. That little port up under the table don't do squat.
Ray
Here's Mine
Garrett in Victoria
>Jigsaw with metal blade. Amazing increase in collection efficiency.
I removed the original 4" fitting just below the blade guides, and used 1/4" plywood - painted to match the finish - to block the opening.
I would have put the port in the back of the saw - a 20" - but it has a double wall there, and it was just too much trouble.
Cheers, Garrett
Re: hijack - Deltas w/o hinged doors??
mike hamilton
>I'd love to see dust collection ideas on older Deltas. Mine is from the mid 60's, Rockwell/Delta, two bolts each and the wheel covers lift off, far from a tight seal around the wheels.
Thanks, and sorry for the hijack,
Mike
Jesse Cloud
>Actually, Delta makes an optional improved dust port that fits under the lower guides. It provides a 4 inch port.
I cut a hole in my door, but the results weren't great. The Delta part works better, but still not great.
