While enjoying the wonderful shopping experiance at my local Lowes I ran across a system that uses co2 bottles to power a nail gun or other air tool. The bottles are about the size used by paintball guns. Anybody use this system? I would use it for installation work, driving a brad here and there, seems nice and compact and way lighter than bringing my compressor or the air tank i use sometimes.
And does anybody know why the lightbulbs at Lowes are not in the lighting section but 6 rows away.
>but they got you to look at all that merchandise between the lighting department and where the lightbulbs were located, So whats so crazy abot their store layout now?
>Thomas, I saw that CO2 setup at Lowes a few months ago. Pretty neat concept, but I thought it was pretty expensive. Not only do you have to pay for the setup, but the cost per "shot" was pretty stiff. Also, there was some discussion about how long the canisters would last if you did not use them. IE, they might leak down.
Many years ago I ran my framing nailers off tanks of nitrogen. They start out at 2200 PSI and you could nail about a hundred sheets of plywood onto the roof for about $15. Fifteen cents a sheet was a heck of a deal. No compressor to buy, no noise nothing anyone would want to steal. But, they "outlawed" it as too dangerous. The guns would fail and blow up if the regulator failed and passed tank pressure to the gun.
You can do the same thing with regular tanks of CO2, just buy a regulator that fits them and buy the tanks. Much larger than the tanks you saw at Lowes. These would be used to carbonate drinks in fountains.
I ended up buying a little one gallon compressor from Harbor Freight. It is smaller than a five gallon bucket and weighs ten or fifteen pounds and came with it's own curly hose. Perfect for toting from job to job and driving a few nails. So perfect in fact that my friends keep borrowing it. It cost about $60 bucks and was less than $75 with an extended warranty. The obvious disadvantage over the CO2 system is that it requires electricity. It is a Campbell Hausfel, a name brand, even if it is make in China.
>I was thinking of it for an install I have That all I need to do is drive 4 23 gauge pins. If it works well for stuff like this the cost would work well for me. I think the compactness is a real plus for me and it would really only be used on smaller installs were bringing my little compressor is a pain.
>i have one and it would be perfect for what you want to use it for. i haven't kept track of how many nails i can shot per refill, but at $2.50 /refill at dicks sporting goods it's worth it for me.
>There was another company that came out with a rig like this before Lowe's, can't remember the name. I built something similar based on their product announcement.
I started with a standard "remote" paint ball regulator on the CO2 bottle to get the pressure down to something manageable. Used the coiled paint ball hose to go to a second small regulator with gauge and a quick connect at the tool. For one project, it shoot over 300 18ga staples on a bottle of CO2.
If you treat the valves on the CO2 bottles well and keep a cap on them when not in use, so that they stay clean, they don't tend to leak down. If you leave the regulator on, it will likely leak down.
Lowe's is a bit pricey for the CO2 at $36 minus the $27 trade in value of the bottle, gives $9 for $3.50 worth of gas.
