OT -Firefox tool bar
Carol - now in NC Nebraska
>Somehow, the tool bar with the back and forward arrows, refresh, home, etc. disappeared.
How do I get it back?
Latest Firefox update installed.
Thanks.
Thanks.
Re: OT -Firefox tool bar
Rod Peterson -- Ormond Beach
>Right click on the toolbar. The top choice is "Navigation Toolbar." It probably won't have a checkmark. If it doesn't, click on it. Your toolbar should come back.
If you didn't already know, you can do some neat customization of your tool bar such as adding a "New Tab" key (which I use a lot) or removing the "Home" key (which I never use) making your arrows larger or smaller or replacing them entirely with text. Start out by right clicking on the tool bar and then select customize. Just move the desired objects from or to the tool box. You can add more separator bars and other things.
Rod
Dan Donaldson
>Click view, then toolbars, then make sure the navigation toolbar is selected.
Re: OT -Firefox tool bar - thanks, guys
>I always wonder how these things happen. I didn't realize I was playing hide and seek with the darn thing. :)
BTW, Rod. I love the new tab button. Thanks for that tip.
Dan Donaldson
>Control-T will also get you a new tab and control-n gets a new window. Control w will close the active tab, or the application if it is the last one. If you like tabs, I would suggest installing the tab mix plus plugin. It gives you a lot of control on how your tabs work. The one that works well for me is the undo close tab for when I accidentally close a tab when I didn't mean to ;-)
I use a logitech Revolution mouse and have the buttons setup to do most of the control keys so I can navigate easily without touching the keyboard if I want to.
