5/0, 6/0 steel wool?
Nick
>Does anyone know where to get 5/0 or 6/0 steel wool? If not, what is the best substitute?
Nick
Re: 5/0, 6/0 steel wool?
>I use 1000 grit or higher sandpaper, micormesh sandpaper or automotive polishing compounds when I need to go higher than 4/0.
Dick Coers
>What John said, plus abralon abrasive pads.
David Yoho
>As far as I know, these do not exist. If they do, I'd sure like to know where also.
David
Keith Newton
>If you are wanting to really get a high polish on a finish, I use 3M 05973 rubbing compound on a buffing head, although I will work by hand also. It just takes a bit longer.
It is a white cream, so all pores need to be filled and sealed, or it will show up white in them.
You can find it in good automotive supply stores.
Nick
>Most recently, I read about 6/0 in a post on this messageboard but I don't remember where or when. I like steel wool-it lasts longer than the fine papers but I haven't tried the loose abrasives like pumice,etc. Thanks for the advice.
Dale Lenz
>I Googled earlier today 00000 steel wool. It's there but it's in another country, not the USA. Could be a different grading system. Dale
Oh, they exist. I have both
Michael Dresdner
>I have both 5/0 and 6/0 steel wool out in the garage. They are not common, but they exist. The brand name on mine is the most common steel wool brand name in America: Rhodes American.
Why am I not surprised?
David Yoho
>I guess if anyone knew if these grades existed or had some, it would be you, Michael. Thanks for confirming they do exist.
David
here is the google search
del schisler
>http://www.google.com/search?hl=en&ie=ISO-8859-1&q=Rhodes+American
Bob Hicks
>Nick:
I'm not a finishing expert, but here's what I can tell you. Louise Stickley, the wife of the late Leopold Stickley, co-founder of Stickley Furniture, was a family friend before she died. Not to give away any trade secrets of another but, Stickley originally used a pumice rubbing powder, using a circular rub, followed by a rottenstone circular motion powder rub. The lube was mineral oil and it was used on all the lacquered finishes (lacquer still used today by Stickley). If you've ever seen any of their pieces, the finish is like glass.
