My Latest Project
My Latest Project
Bart Goldberg
My Latest Project
Bart Goldberg
>Hi all,
My latest project completed.
Its a table/bar that will be installed in my brothers new kitchen.
Its a monster - 43" high, 70" wide and 24" deep.
Its made from a unique type of rather expensive bamboo plywood called Plyboo.
Nasty stuff to work with - very splintery and very dense and heavy - but looks cool - kinda like Zebra wood.
Only a decorator could have come up with this stuff.
I had to laminate two sheets together to make the 3/4" thick sheets
into 1 1/2" thick sheets to make them thick enough for a counter top.
I also had to rip off the face veneer from some scrap and apply it to the exposed plywood edges to cover them up.
Joining the side to the top was a bit tricky - Originally, I was going to do mitered joints with splines -
However, that would have been a bit difficult to align during construction do to its size and weight- So I decide to do a lap joint instead.
I cut rabbits in the sides of the top - leaving the top surface veneer in place so that the top was an unbroken surface.
Then glued the sides to the top using epoxy - nice and strong. However, to reinforce the lap joints, I added
Walnut Miller dowels - I thought a nice color match.
To cross cut these huge sections to size accurately, I had to construct a sled for my table saw.
That alone took almost an entire day to construct - but was necessary to be able to make accurate cuts on my table saw.
Once the whole thing was constructed, I had to completed cover the piece in 2 part epoxy to
encapsulate the grain to deal with the splinters and fill in the many voids in the surface.
Sanding off the epoxy was not fun.
Then I sanded the whole table to 600 grit and applied one coat of Gel Poly.
Three or more coats of poly and it will be ready to be delivered.
Note the wheels are temporary - just to be able to move the thing around by myself while finishing.
Enjoy
Bart
P.S. Special recognition to a great friend, John Chase, who spent several days at my house helping me construct this monster.
Re: My Latest Project
Bart Goldberg
Re: My Latest Project Pic 2
Bart Goldberg
Bart Goldberg
Bart Goldberg
>Lets try that again
Bart Goldberg
Re: My Latest Project - Pic 3
Bart Goldberg
Wow, that's cool.
Steve in Fresno Go Dogs!!
>Some of the simplest projects can be the most striking and the biggest pains in the butt.
Thanks for sharing.
Not a criticism, but a question…
Rod Peterson -- Ormond Beach
>Whenever I see a structure like that all I can picture is the tremendous leverage of those long legs working against the comparatively tiny joint surface at the end of them. I gather from your remarks that it ultimately will be firmly planted on the legs, but isn't it vulnerable in the meantime? And how will you protect the joints while moving it? Are there any hidden fillets or braces?
Rod
Bart Goldberg
Re: Not a criticism, but a question�
Bart Goldberg
>Rod,
Your very observant -
I had the same concerns.
For transport to my brother's house in NYC, I plan to attach some
support braces across the bottom to prevent any racking or undo stress.
Once in place at its final destination, it will sit over the top of a cabinet that will support its weight over half its depth and over its entire length.
Thanks for posting
Bart
Suggestion, then…
>> For transport to my brother's house in NYC, I plan to attach some support braces across the bottom to prevent any racking or undo stress.
What door manufacturers do when shipping pre-hungs is to tack a strip—probably no more than 3/16"x1½"—across the bottom. I'd use two in the case of your wide legs—one toward the front and one toward the back. But that only addresses splay. To avoid racking, you'd need a diagonal of some sort. Same sort of strapping but from the upper end of one leg to the lower leg of the other. You could do it across the back, although that might still leave some vulnerability in the front, or just put a couple on the inside of the unit—one toward the front and one toward the back—in each case going from the top of one leg to the bottom of the other.
In all cases, any holes left by the fasteners used will be buried out of sight after installation. But you've probably figured all of that out.
Rod
