Drying whole tree trunk
Paul T
>Hi all,
A small tree had to be taken down. It's about 5 inches in diameter. I don't know the species, but I think it is commonly used for knife handles and such. It is straight and I thought it would make an interesting top rail for a railing in my shop. I would prefer for it not to check/split. Would you strip the bark and seal the ends, or leave the bark on and seal the ends...or something else? Location is upstate NY where it looks like winter has arrived.
TIA,
Paul
Re: Drying whole tree trunk
I'd say leave the bark on and seal the ends....
Scott in Eastern Iowa
>....it will dry slower for you.
Later on you can then strip it off and fashion the railing as you wish.
It may split, regardless
Bill Tindall, E.TN
>Depending on species it may split. the tangential shrinkage of many species is greater than the radial shrinkage. translation- the diameter of the log may shrink much more than the circumference. This differential shrinkage will result in tension that will be relieved by a pie shaped split forming the length of the log. It will matter not whether the bark is on or not.
I have dried white birch and pine in 5" log form and not gotten splits.
r payne
>Depending on species and what time of year it was cut, the bark may come off on its own. Even if it didn't, I'd debark the log because there are a lot more bugs that like to start eating the inner layer of bark and keep eating into the log. Most of the moisture loss will be through the ends regardless if it is debarked or not so definatly seal the ends (wax, paint, sealer, tar, glue: I've seen all these recommended, I've only used a lacquer based sealer [sorry don't recall the name]) The log also should not be in contact with anythning that will hold moisture next to it (unless you are trying for a spalted look) that includes dirt, concrete and plastic amongst other things.
ron
Jim Swank
>Seal the ends, leave the bark on if it is sound. Consider cutting a kerf the length of the log through to the pith with a chainsaw. This will create a place for shrinkage to occur and should avoid splits developing in other areas. This is a woodcarver's trick. You can always fill in the kerf after drying, with spline or other fill of choice.
john l. blue
>I'd strip the bark, let it bask in the sun a day or two, then seal
it.
Dubious success drying whole trunks.
Forrest Addy
>Dubious success drying whole trunks. The project is frought with peril. Checking, spalting, honeycombing, and very long drying times are equally probable. The problem requires strategic thinking.
At the very least consider the end use of the trunk and the species response to moisture change.
If you plan to dry the trunk and saw it later into lumber, forget about it. It will check and spalt like crazy and take 10 years to get to usable moisture ocntent. I strongly suggest if lumber in your goal to saw it into thick slabs for later re-saw. I used to have the local WoodMiser guy riff saw the local maple into 7 1/2" thick timbers boxing out the heart or leaving it in a corner. This thick materl is slowly cured over that fall winter and spring and protected from rapid moisture change in the summer. If this regime s followed over 3-5 years it resulted in sound 28/4 lumber easy to resaw. I used to use it for my world famous timber fireplace mantles.
If the trunk is to be used as a "statement item" where its intact shape and texture contributes to a whole (such as a stair case coener post) you'll almost have to figure on a certain amount of checking. Allow the trunk to dry for a few days so the ends lose some moisture. Look at the heart. You'll see a pair of cracks radiating from the heart in a 5 o'clock configuration. These represent natural checking plane. As the truck dries, the predominate checks will follow those planes. If the checks are to be minimized any radial relief cuts have to follow them.
If you hope to minimize checking some chainsaws relief cuts will have to be made. If the truck has branches then the problem is far more complex. I've seen whole trunk architectural elements cured to 8% MMC that were relief cut when green, the jointed and assembles when cured. When done carefully and the bark stays attached the joints are nearly invisible but it's touchy skilled work.
I suggest quartering the trunk around the heart and allowing it to dry. What was once 90 degrees will with normal shrinkage become about 85 degrees. Careful rowk with a hand plane can re-join them into accurate quadrants. I suggest you cut away the apex to about 1/2 radius while the quarter are still green. This results in a hollow column when the quaters are re-assembled. You'll have far quicker drying time, less checking, and easier assembly of the quarter when the drying is complete - and less liklihood of subsequent checking.
Good luck.
>Green wood has been used for building for thousands of years. I would seal the ends and leave the bark on or take it off; it's your decision based on how you want it to look. I think the bark will stay on a tree that is cut in the fall if I remember right; if cut in the spring or early summer when the sap is really running it will come off I think. It will shrink/move some but mostly you just live with it.
Just 5 inches in diameter?
JohnKJordan in East TN
>Something that small may dry fine, depending on species and the individual tree. For example, most dogwood that size will split like crazy, I've had some open a 1" gap. But I've had other small dogwood logs not split at all. Other species, like eastern red cedar, never split (in my experience).
What I would do: certainly end seal with wax or anchorseal, remove the bark if you don't want to try to save it, keep it out of the sun and rain, and keep my fingers crossed.
As for using it for a top rail, that sounds great. A friend of mine hauled fairly large black cherry logs out of the woods and used them as beams across the open space of the great room in his house, bark and all. They still look great after 20 years. He was perhaps fortunate not to have problems with splitting or bugs.
Keith Newton
>Here in the South, it would be a much better idea to get rid of the bark because of the insects, although your milage may vary. If you peel the bark, the exposed sapwood will dry much faster than the heartwood can give up its moisture to the sapwood layer, which will lead to the checking, so I would suggest to seal it with something like the oil finishes, to slow it down,
Aside from that, if you drill out the pith center from the ends, it helps relieve some of the tension caused by the differing tangental, and radial values, by eliminating the support that the ray cells coming together at that point seem to cause.
I have noticed while harvesting wood for my turnings, that those trees which are hollow, manage to dry without the usual checking of trees which are solid to the heart. I have drilled out a 1.5" diameter hole of the heart on some sculpture pieces, and feel certain that it helped. I plugged the ends after they had dried.
Also, the stair to my sleeping loft are mortised into a cherry tree, which I found that had been dead for a long enough for the sap-wood to decay and be missing, leaving a weathered heartwood trunk. When I constructed this stair, there were checks which were larger than they are now, 24 years later. It has a hollow about 5" diameter running up the middle, which I am happy was there. Some of those checks were around 3/8", and are now only about 1/8".
