OT changing the light bulb!
Philip Duffy
>OK, lets get the jokes out of the way first; How many sailors does it take to change a light bulb at the top of a blind stairs? Just one, but it takes him 2 hours!
Got a reach pole with a sticky plastic attachment; not a chance to pull that bulb 8ft up the stairs. Tried CA glue next; no chance. Got a basket arrangement as well; no luck, but it sure got all the paint off the insides of the bucket where the bulb sits. How about an invention? Sure enough, a piece of 150 sandpaper and some hot glue to hold it in place on a turned base of wood, and some more hot glue to stick to the bulb, and Voila! A bulb is out! The new bulb is one of those energy savers with a squirrel cage look so I made an insert with two dowels on a piece of wood that holds the hold thing in place while you screw it in. It works. - -just don't pull the dowel piece out without considering the fragility of the energy-saver bulb. Be careful of the broken glass all over the stairs! And, don't forget to lube the threads on the new light bulb. Philip
