E-Zine wind chime tips
henthorn
>For anyone making the wind chimes featured on the recent WW Journal e-zine here are couple of tips and commentary to make a more successful project.
1. You will get the best response by drilling the holes 22.4 percent the length of each tube from its end. This will place the hole at one of the two nodes of the sound wave, giving the most volume.
2 Contrary to what the article says, the best places for the striker to hit the tubes is either at the mid point or the very bottom. Striking them any where near the nodes will dampen the sound. This means that if you elect to hit the tubes at the midpoint then each tube must be hung so that its midpoint is the same distance from the support ring as the rest of the tubes. If you want the tubes hit at the bottom then the tubes must be hung so that the bottoms of all of the tubes are at the same level.
The larger the tubes the more dividends you will get from following these tips. Cheers!
