Makita 3612C
Makita 3612C
Makita 3612C
Nathan
>I need a bigger router for my router table and I'm considering upgrading to the Makita 3612C. I must say a big factor in this decision was Garrett's $2 router lift article. Before I order the tool, though, I wanted to ask those of you who have one and might be kind enough to respond, a couple questions:
1. Is there a switch in the handle? I can't tell from the pictures. In some of the pix it seems like there is. The hole in my table is quite small and I don't want to enlarge it too much, so the handles would have to come off.
2. With the handles (more or less permanently) removed, what is the tool's girth at its widest point. This is for purposes of fitting it through the exiting hole in my table, or to find out by how much I will need to enlarge it.
3. Does this router have enough power to cut raised panels and cope-and-stick joinery?
Thanks in advance.
Nathan
Re: Makita 3612C
Re: Makita 3612C
Keith Newton
>I have several Makita 3612's but none are C. The motor is 5 x 8 5/8" with the handles off, to the end of the roll-pins which index the handles. With the handles on, it is 11 w. The base is 6 5/16" round. The height is about 12.5"
If they still make a square base option, I would choose one with that option, although I have not seen that offered in a long time.
The switch, rather than a squeeze trigger, on all of the three that I have are a little toggle that sticks out of the side of the housing just in front of your fingers of the right grip, so you flip it up to turn on and down to turn it off, and the opposite of that when it is under the table.
I don't know if
Re: Makita 3612C
Any VS router can be used to raise panels
Chris Knob
>As long as you know the limitations. Even with a big 3hp machine, you have to take multiple passes with the biggest bits. Routers of under 2hp are best served by vertical panel raising bits but even with arge horizontal bits, 4,5 passes can get you there. As long as you remember even the biggest, beefiest router in a table wont come close to the performance of a 1 1/2hp shaper, you should have no problem raising panels with modest router hp. If your work requires most efficient use of time, dont raise panels on a RT.
Re: Makita 3612C
Re: Makita 3612C - Further Comments *LINK*
Garrett in Victoria
>Hi Nathan
You're the second person this week asking about making this modification. (His was by e-mail.)
The only difference between the 3612 and the 3612C is that the latter has a variable speed control, an important consideration for the large bits you want to use. It's an excellent tool, and in 8 or 9 years of use, I've never had it bog down under load. Note that the collet is designed to automatically free the bit. When loosening it, the collet comes free, and then comes free again. It's the second 'give' that ensures you can lift the bit out without difficulty. I'm less thrilled with the the 1/4" collet insert, however, but it works. (It's held on the outlet box by a magnet in the photo below.) IMO, Porter Cable has a still better collet system, but it requires 2 wrenches, one of which always - and frustratingly - slips off the very thin lower 'nut'.
As to the switch, Keith has pointed out that that the 3612 has a toggle switch. However, for convenience, it's far better to put a switched outlet box on the router table. That gives you two useful features. First, you leave the Makita's switch always on. and use the switch on the outlet box. Second, since the router's plug is always to hand, there's no excuse for not unplugging it when changing bits. I also swapped the Makita plug for a 90 degree plug so the the cord hangs straight down.
If you go ahead with this project, you might also want to refer to my article on making a simple remote shaft lock so that you can make bit changes above the table without having to reach under to hold the lock button in.
Cheers, Garrett
Makita Remote Shaft Lock
Re: Makita 3612C
Re: Makita 3612C *LINK*
Nathan
>Thanks for the measurements, Keith. The reason I asked about the switch is that in some of the pictures I've seen (the 3612C seems to exist in at least two versions), there appears to be some kind of switch on the handle. The following link will take you directly to the picture.
Makita 3612C
Re: Makita 3612C
Re: Makita 3612C
pecker
>Here'a pic of mine "upside down" on the router table. The switch is on the right body...a lever you flip up and down with your thumb when using it handheld.
My router plate is 9" x 12" and did not require the handles be removed to fit. Using the supplied collet wrench and shaft lock button, I rarely even need to remove the router from the table to change bits.
