amount of lumber needed
Bill Lowery
>Hello and this is a great forum!! I am building some cabinets for my Sister and I am ready to start the face frame,door and drawer front construction, my question is, is there a simple formula to figure how much stock I would need?, such as for every 5ft. of cabinets x amount of stock is needed? Or some other formula I can use to figure this out.. Thanks in advance and again Great forum!!! Bill
Re: amount of lumber needed
steve - Denver
>Check out the cabinet design spreadsheet, about half way down the page, might be too much detail.
http://www.free-woodworking-stuff.com/docs/woodworking-software-download.htm
marc rosen
>Hey Bill,Others,
I made up a spreadsheet in Excel (although I am sure any spreadsheet program would work as well). I am attaching it but if the attachment does not fly I'll explain it in brief. (This is my second attempt to send this. I was not able to send the Excell Spreadsheet but if anyone wants to contact me directly I will send an attachment to them)
My columns are ;
Item number (or piece),Description, Quantity, Thickness, Width, Length, Board Feet/piece, BDFT/quantity, and a summed column labeled total BDFT.
Excel lets you enter the dimensions as you would cut them; i.e., 1 3/16 inches. For BDFT/piece set up the formula Thick x Width x Length and divide by 144. BDFT/qty is a simple multiplication of QTY by the BDFT/piece column and the sum is a sum function adding all the values in the BDFT/qty column up.
Obviously this spreadsheet does not acount for waste but it gives you the minimum amount for the finished product.
Hope this is helpful to someone out there.
Marc (who owes his carreer to the developers of Excel)
Ed Mulligan, Cape Cod
>Bill,
The usual method is to figure it out piece by piece as the above posters have said. But this only gives you the amount of wood in the completed item. You will have to buy more to allow for waste and defects. How much more depends on the wood species, wood grade, and your design. For instance, will the cabinets be finished clear or painted? Are small tight knots ok or do you want only clear wood? If you are using cherry is it ok to have sapwood visible or not? Answers to these questions will have a huge impact on the amount of wood you need. My experience: for painted FAS poplar plan on buying 10 to 20 percent more wood. For FAS cherry finished clear, no sap, figure on doubling (100%) the wood order.
In lower grade wood you will pay less per board foot but will usually have to buy more board feet to get the stock you need.
Ed
Chris Knob
>Waste percentages vary by species and grade...and by what sort of final appearance you are lookig for. You want to hit this plus or minus 10 percent idealy. No one wants to slog it out to the mill in the middle of a project or have overspent for stock. Best thing to do is figure things out on a piece by piece basis and multiply by 25%.
>It would be fairly easy to add a waste percentage, multiplying your sum by a cell where you would entered the desired waste percentage. I am having a lot of fun with excel. Last year I quoted furniture for a hotel, and set up spread sheets for each individual piece then linked all the prices and quantites together on the front page, and added cells where the business owner could enter the desired labor figure per minute. Entering a different waste percentage for the materials and the labor rate were two variables; it was fun to change the numbers and watch all the other numbers change.
Re: amount of lumber needed *LINK*
Jim Dillon
>Bill,
Another option is CutList Plus. It offers a lot of options and a trial download. When I did my kitchen, I found it superb for sheet goods, but less so for the hardwood fronts etc. though it still got me in the ball park. It is less useful because for the reasons mentioned by others: sapwood, defects, grain matching, etc etc. I've used it on other projects and found it to be helpful. Good luck.
Jim
CutList Plus
Re: "multiply by 25%" Should be: by 125%
Dave Bair, Eaton Rapids, MI
Correct...Thanks
Chris Knob
Jack
>Bill
If you want to save a little time and effort with this job this might help. I own a cabinet shop and we have gone completely to 2" face frame stock that we buy from our lumber supplier. It's run through a moulder and is ready to cut to length and build the frames. They keep oak, NSM, cherry, poplar, and hickory on hand. They'll run whatever you want for a slight upcharge. It sounds a little pricey when you first get the numbers but there's virtually no waste and it's fast. Also, the lumber is usually very clear, straight grained and from the same run. Very little grain and color matching necessary. I pay the following in MS: .78-red oak, .99 NSM, 1.30 cherry, .78 poplar, 1.09 hickory. I'm sure you have a lumber yard in your area that supplies the same product. Many shops have gone to it.
I use a cabinet design program called Cabinet Solutions that has almost no learning curve. I was drawing cabinets in 30 minutes. They have a 2 week free trial version that gives you full use of the program to inlcude graphics and cut lists. It tells you to the inch how much frame stock you'll need as well as plywood requirements, optomizing, assembly schedules etc. It provides a door and drawer front list also. I would think you could get everything you'd need from the program in two weeks. BTW, It costs around $3K to buy it or you can lease it for $100 per month.
Good luck
Jack
Cabinet Solutions
