Battery Charger Help
Don Orr
>I have some older Porter-Cable cordless drill/drivers and am having trouble with the chargers. These are model 8501 12volt chargers and have been discontinued. I called our local repair center and they say they do not repair chargers at all. One charger is only putting out 0.1 volt and the other is putting out 20 volts. I just had some of the older, worn-out batteries rebuilt and now the chargers decide to act up. Is there any way to have these chargers fixed ? I called 1 local electronics repair place and they said they could not help me.
Any ideas? I like these drills and have a bunch of batteries and hate to just dump (recycle) them. I have not had a chance to look on the 'bay yet.
Re: Battery Charger Help
Dale Lenz
Re: Found this... *LINK*
Dale Lenz
>on Ebay. Good luck
Charger
Bruce, a MN Galoot
>Don,
I have precisely the same problem with my B&D 9.6 Univolt drill and charger. Well, charger, at least. Drill's good, batteries are good, charger is shot.
After a couple months of trying to find a replacement, I was ready to give up. Then, one day, I happened to ask our instrument tech at work (I work at an electric utility). He said, sure, they can be repaired. And then he rattled off what usually goes wrong with them. It's normally a diode of some sort or another.
Anyway, that's my suggestion. Don't go to a store. Rather, find an instrument tech at some big installation. They have to make things work and frequently those machines and instrument panels aren't supported as well by the factory as they should be. Maybe this is easier said than done, but it's worth the effort.
Bruce
Try Radio Shack
Lee Schierer - McKean, PA
>Radio shack has a number of power supplies with adapters to plug into various devices. If you know the output polarity, voltage and amps (millamps) then they might be able to fix you up with a charger. They helped me with a charger for a rechargeable flashlight that was discontinued.
Lee
>I agree that they can probably be repaired. I have a friend that could do it and I will probably see him around Christmas time. Let me know if that is your last resort.
Call the people that rebuild the batteries for suggestions. The ones that fixed yours and others as well. They may have insight into how to do this or where to get help.
You could... buy a new or different brand of charger used and cobble it together with the one you have. Find the out put wires on the newer charger and hook it to the equivalent wires on the old charger so that the new charger is connected to the socket on the old charger. Crude, but it might work. You might even be able to put the guts of the new charger into the old box.
BTW, what's wrong with 20 volts? The output has to be over twelve for it to charge. What's it supposed to be?
Don Orr
>Thanks everybody for all the great suggestions. Never thought of Radio Shack !
Barry, I have read that over charging rechargeable batteries dramatically decreases their life span. I charged one of my batteries on the 20 volt charger and it measured at 14 volts. I don't think that's good for them. Anybody know for sure ?
20V may be fine
>I can not say for sure, bur if you measured it without a battery init, the circuit may be working fine.
The chargers are usually designed to drive a current so that the voltage may well increase to 20 volts when there is no battery. If the charger is designed to handel 18V battery packs as well as lower voltage batteries, 20V makes even more sense.
Re: 20V may be fine
Bill Schreiber, Litchfield, NH
>14V when being charged is fine.
Definitely look into RS for your other charger though.
Good luck.
Regards,
Bill
I just measured 3 chargers
>I measured teh voltage on the pins of 3 chargers (all different brands). They measured very low voltages with no battery in place. They are, however, all are smart chargers and are less than a 4-5 years old.
I did not measure the voltage with a battery in place, but I would expect the voltage to be a bit higher than the rated voltage of the battery, depending on the battery technology. For example, I would expect a 12V NiCAD pack to have a voltage on the order of 13.5V (just an educated guess) while it is charging.
