General jointer ?
Thomas S Stockton
>Hi all
Anybody have any experiance with a model 280 14" General jointer. Looks like a nice machine and General has a great reputation but would like to hear anybodies experiance with this tool.
Tom
General jointer ?
Thomas S Stockton
>Hi all
Tom
Re: General jointer ?
Barry W. Larson
>Hi Tom:
I cannot comment directly on the General model 280 jointer, but I do have a 12 inch 780 jointer that I quite like. One of the things I like about the bigger General jointers is they have small inclines at each corner of the tables which means that each corner is independantly adjustable. I also prefer this system to either the old standard wedge bed designs or the "newer" parallelogram jointers because the tables are supported on the corners instead of in the middle - no worries about table droop on these machines. My 780 has an 84 inch bed so you can joint pretty long material very easily.
Do you have any additional information on the model 280 or even a picture you could send me or post. I am familiar with most of the newer General models, however I have seen a couple of three toed Generals which have beds very similar to my 780 but rather than sitting on a solid case base they sit on a 3 legged cast iron base. I wonder if this might be a Model 280 (I am also assuming this is a Canadian General and not General International). One additional thing - I had never heard of General making a 14 inch jointer - so this is also news to me.
Thanks,
Barry W. Larson
Calgary, Alberta, Canada
Re: General jointer ? *LINK*
Bill Howatt
>I got curious. I couldn't find anything on the General site but I found this on ebay. Appears to be an oldie.
General Jointer 280
Barry W. Larson
>Hi Bill/Tom:
This is the type of General jointer I have seen on a few occasions but didn't know the model number. I believe these are quite old, likely from the 50's or maybe the 60's (though I doubt if they are that new). I didn't realize they were 14" machines (never thought to measure). Except the for the odd blade size the table set-up is the same as my 780 with wedges at each corner. The three toed design allows the machine to be stable even on an uneven floor. The fence is an older design with the ability to easily skew the fence for jointing knarly grain - something that is difficult to do with the fences on the 780 and 880 jointers. In short Tom, if the price is right and you have the room this would be a great machine especially if it has a 4 knive head.
Barry W. Larson
Thomas S Stockton
>Yup that's the one shipping and putting it on a pallet are about $900 so I got to figure what I can spend and if I even met the reserve price.
Tom
Thomas S Stockton
Tom
The 780 is the modern version of the 280
JRutter
>I called General to inquire about parts, info for my 280 and they sent the 780 manual. It is indeed a 12" head, not 14" unless it has some custom head installed. The fence IS nice.
-JR
Re: The 780 is the modern version of the 280
Thomas S Stockton
>Thanks JR,
14" sounded like a wonky length nice to get it clarified, do you like your jointer and does it have any quirks. And if you don't mind telling how much was it? I like the fences that attach to the beds as opposed to a long arm that takes up a lot more width
Tom
JRutter NW WA
>Tom - It is a simple and effective design. The tables are supported in the 4 corners on a sub-assembly that slides towards and away from the cutterhead to make knife changes easier. The 3 point base means no rocking around. The whole machine is very massive, with thick castings. I agree on the fence - this machine can go up against a wall easily. When I bought it, the exchange rate was going the other way for a net cost of about $660 USD. Someone told me that it is a patternmaker's jointer, thus the relatively short tables.
It has been a real workhorse in my shop. Here is a picture of how mine has ended up dedicated to facing with a power feeder and Shelix head. I still have the fence and guard squirreled away in case my situation changes.
