Veritas - Innovation in Tools
Cutting Door Jambs Quetion?
>A friend needs to cut off the bottom of door jambs to allow for installing laminate type flooring. Was thinking of renting a Jamb Saw. Any hints?
It occurred to me that my plate jointer or biscuit cutter might work. It seems the top of the blade is about the right height off the floor. Has anyone tried using a biscuit cutter for something like this? Mine is a Poerter Cable.
Re: Cutting Door Jambs Quetion?
Re: Cutting Door Jambs Quetion? *LINK*
Grant in Iowa
>Barry,
I think the biscuit cutter would work, but be advised that the blades for them aren't cheap and you might hit a nail or two. I just bought a CMT biscuit blade for my Porter Cable, and it was $29.
You can buy a hand jamb saw for about $15 or so that will make a jamb cut in about two minutes. They have a thin kerf and a reversable handle for left and right hand use. You lay a scrap piece of the laminate on the floor adjacent to the jamb to be cut, and then lay the saw atop the laminate to reference your cut. Here's a link to one that I own from a website I googled up for you...
These are also available locally at Sears and the big box stores such as Lowe's.
Unless you have 10 doors to cut, renting one is probably not worth the effort.
Regards,
Grant in Iowa
Irwin jamb saw
Ahh, a question I can answer…
Rod Peterson -- Ormond Beach
>…(as opposed to the questions I do answer but may not have an answer for…or something).
I used my Elu biscuit joiner (essentially the same as the Dewalt) on several door jambs (at least 18 doors, which is x2 jambs), both on my house remodel and my daughter's. It worked great. Fortunately, it's quite uncommon to find fasteners that low in the assemblies (and they're generally soft staples when you do), so your blade probably isn't at very much risk. The only downside is the cut winds up perhaps 3/32" higher than you really need, but after all the flooring is down and you've done all the baseboards and shoes, you won't even notice it.
Grant's suggestion for the fine hand saw is a good one with this caveat: it is a knuckle buster in that application, and I would only recommend it for finishing cuts as a supplement to the biscuit joiner (you can usually get all the way through the actual jambs with the biscuit joiner, but you often can't get all the way through the casings due to adjacent moldings which are already high enough off the subfloor). I would rather watch a reality TV show than have to do more than one or two jambs solely with that hand saw. I have a Kuntz which I inherited from my father and it worked quite well (except for the knuckles).
Rod
Link Van Cleave
>Agree with Grant. As a finish carpenter I have done many hundreds and never needed any more than one of those saws that Grant mentioned. Not a knuckle buster as the handle is off set. A japanese saw works well also.
Link
Joseph Mulherin
>Barry, go to Lowes in the tile dept. and purchase a sill cutoff saw they have especially for this sort of job. It has the handle on top so you do not skin your hand trying to saw with a regular type of saw. Also, it has teeth on both sides of the blade.
$100 Best I ever spent
Dustmaker Mike
>I went to Lowes and bought the Boush Trim saw. It comes with 3 different style and length blades. I used it on two different jobs now and love it. If you only have a few to do then the hand one works great but if there is a lot then Go with the Power.
Mine is offset, too. It's a knuckle buster. Maybe I have big knuckles, although they're not as big as they used to be after using that saw to finish up some jambs…
Rod
Wish I'd done this!
ScottS
>I put laminate flooring in my house last year. I bought a flush-cut Japanese saw, but eventually ended up using my ryoba. The blade on the flush-cut saw just wasn't long enough. The ryoba worked surprisingly well, though it wasn't designed for this job. Still, doing the 12 doors that I had to do was a chore; my least favorite part of the whole job.
When I found out that I could have purchased a Bosch 1640VS for $100, I was kicking myself for all the time I wasted doing it by hand! For another $50, the 1640VSK includes a case, a small mitering jig, and some clamps.
Re: Am I missing something here
Earl
>Why couldn't you just scribe a line where you want the cut to be take the door off and cut it with skillsaw? Earl
Yup sort of
Dustmaker Mike
>by cutting them in place you save time. If you have to remove lets say 5 door frames then cut and replace them you stand the chance of putting at least that many holes in the wall.
Bill White
>Earl,
The discussion is about cutting off the door frame (jamb) not the door itself.
Bill
Re: Wish I'd done this!
Andy Lincoln,In Dearborn MI
>BTW,
The mitering jig does a fantastic job of cutting all the shoe molding that needs to be installed after doing the laminate flooring.
That was my intended use and subsequently discovered the ability to cut the jambs,etc.
Andy
Does taking out three hinge pins really
henthorn
>take that long?
