OWA 2x4 contest winner is...
TiO
>Denis Chenard of WoodCentral fame!
Re: OWA 2x4 contest winner is...
Congrats, very nice work Denis!
Norman (Metcalfe, Ont.)
What's OWA?
Paul Woolson
Bill Schreiber, Litchfield, NH
>Denis,
Very nice work. I like the design.
Regards,
Bill
Congrats, Denis- Nice Job!!
Ron Hildreth
The Ottawa Woodworker's Association (OWA)
Brad in Ottawa
Brad in Ottawa
>Congrats Denis!
Looks really fancy for 2x4 furniture!!! What are you going to do with it?
Brad
What a neat design. Congrats Denis!
Jim Dillon
Alan Young
That looks like a very attractive design.
Alan Young
>Congratulations Denis.
Alan
Who's that ugly guy? :-)
Denis Ch�nard, Orl�ans, Ont.
>At least the table looks good, from a distance...
The inspiration came from Ted Brown's two part series in Pop. Woodworking. I've always liked floating tops and had done one about 10 years ago for a hall table.
Reading the article, I started calculating lumber requirements and found out that I could make a table of that size if I used a full 2 x 4 (which the rules allowed). Finding the piece (had to be pine as per the rules) was more problematic, as the construction requires clear stock as much as possible (you don't want a big knot in the middle of a leg or apron). I ended up using two 1 x 4 (allowed by the rules), which created problems with my cut list (the legs now had to be laminated, for instance).
Construction is mostly traditional, mortise & tenon for the legs and aprons, the brackets for the floating top are joined to the top with sliding dovetails, and the top is attached to its brackets with wooden buttons.
Some parts had to be build differently because of the lumber limitation. The top is actually a bit under 1/2" thick, which would have looked silly, so I made it 24" long, cut off 2" at each end and "flipped" these ends underneath to create an impression of thickness; on the sides I built the thickness using 1" wide stock. In his article Brown had beveled the underside of the top, and I did the same, being careful to plane up to the joint line so as to make it disappear. The aprons are laminated too, the "fretwork" part being shaped separately then applied to the actual apron (which tenons were offset to the outside to make them roughly centered in the final assembly.
I originally wanted to make the top by resawing a 2" thick piece and unfolding it like an accordeon (to keep the grain consistent), but since I couldn't do that anymore given the lumber I used I bookmatched the middle of the top then added another bookmatched set, one half to each side of the middle. Came out OK.
Now what the picture doesn't show is all the little mistakes that I made along the way... The worst one is when I cut the taper on a leg on the outside... Fortunately I was able to patch a piece and salvage the leg, luck has it that that particular leg had very quiet grain and made the repair almost invisible.
I was planning on staining the legs, fretwork and top brackets, partly to hide the laminations and partly to provide some contrast, but I ran out of time (I left the shop at 4 AM on the morning of the show). Now that I look at it I think it looks better than if I had stained the piece.
Much of the work was done with hand tools, and the visible surfaces were hand planed.
It was a fun project, and I will revisit that form in the future, but then I'll use real wood (I hate pine...).
Thanks for the kind words,
DC
In need of a haircut
Correction
it should have said instead "the brackets for the floating top are joined to the aprons with sliding dovetails"
DC
Needs to proofread a bit better
>Thanks Brad,
I will do nothing with the table for the moment, two weeks or so from now the top three pieces in the contest (at least) will be displayed in our booth at the Ottawa Wood Show, so if you come over you will see all the defects on my table :-)
After that it will be used as a sofa end table in my living room, we'll see how long it stays in one piece with three rowdy boys in the house...
DC
Re: Who's that ugly guy? :-)
Jennifer@Indy.USA
>Denis this is a great little table. I love the design and the lines of it. You did a great job with the material allowed.
Very nice.
Jen
