Shellac
Shellac
Shellac
matt ankney
>I have used a lot of finishes including many marine type but I have no experience with shellac. Is it suitable as a finish for a waynsecot or cabinets? Also does the amber darken the wood much I would like to darken the wood a bit , cypress, and thought this might do it.. Thanks for any advice, Matt
Re: Shellac
Re: It's what your Grandpa likely used
Glenn Madsen near San Francisco
>And it worked pretty well.
It's not as durable as a Urethane, but it's more 'natural', being essentially lightly refined bug excretions.
It dilutes and cleans up with alcohol, wipes on with a rag or a brush, sprays nicely with a $50 Critter gun, and sands easily. Polishes nicely. Dries quickly. Cures well. Doesn't cause too many problems, as long as you vent your workspace well. And it's cheap.
Can you mess it up? Yes. Can you recover from that? Likely.
You can tint it with dyes, if they dissolve in alcohol. Or you can use various colors of the base product, if you want to have them around. It's pretty easy to use.
Would I use it on wainscot? Well, if that's the look I wanted. I wouldn't make it my first shellac product. I've done furniture, shaker wall clocks, jewelry boxes, and more with it.
Get some Sealcoat, fresh in the 1 qt cans from the local hardware store, and try some on scrap from the project you want to finish. See how it looks. Thin it about 30-40% with denatured alcohol, and wipe it on. Take pictures.
Re: Shellac
To Add
Mike Fitterling
>Shellac is a gloss finsih in every variety I have seen. You can make it finish to whatever sheen you want after application by rubbing out. One way is pumice rubbed on with a felt pad and oil to get a stain sheen (two grades available of pumice, each will give you a different sheen) and rottenstone rubbed on the same way will give you a high gloss. There are other methods of rubbing out, too, but I will let others comment on those.
Good luck,
Mike
Re: Shellac
Re: To Add
jerry mayfield
>If you want to add color use one of the lesser refined
shellacs ,such as garnet,more natural dye. I love shellac and use it a lot.
Regards
Jerry
