powermatic 90 wood lathe
James Pittman
>I am new at woodturning, and bought this powermatic 90 it was all apart and did not get to try it out.I put it together and got it running, but I had it turning little faster about 1000 rpm when started up. I noticed a little vibaration in it but not bad.I decided to set it up right and slow it down to the right speed when it started up.Now the vibration is bad enough to effect my turning. If I speed up it is not as bad.I need help from someone who knows how to get vibration out.Were do you get bearing and parts for powermatic 90 . HELP!!!! Thanks Preacher
Re: powermatic 90 wood lathe
Ray Binnicker
>Hey Jim,
If you would post this over on the "Turning" board those good guys/gals will jump all over this problem and have you up and running before you can say Thanks.
Ray Binnicker
Keith Newton
>I would guess that the vibration is probably from memory in some old stiff belts, so getting new belts would be a good start.
My main gripe about these, if it is like an old one that I have, is that the sheet-metal base
is too narrow on its front to back footprint, which really needs to wider. If changing the belts doesn't take care of it, and if you think the problem is what I just suggested, you may try something that I did with an older model 45. I picked up some heavy plate steel from the salvage yard, then bolted / bonded a heavy plate onto each end, with feet welded onto the front and back bottoms, which widened the stance about 4 times, and and also added several hundred pounds.
After having done that, the only place that it can wiggle is by flexing the top of the steel cabinet top between the bolts, and these end-plates.
Well there is another issue that I have with that model. They should have located the outboard bearing of the headstock outside of the belt. THe way they did it, makes the bearings too close together relative to the distance out to the faceplate, especially when you add the wood to be turned, is just not rigid enough for my liking. It should be ok for inboard turning though. I do most of my turning outboard, so I never use this lathe, and should get rid of it.
Pete in Holland, MI
>Make sure your v-belts have cut sides rather than wrapped. Wrapped belts for most things are fine, but there is a lap joint that can cause vibration. Could try one of those segmented belts too.
Also inspect all of the pulleys to see if one flange isn't bent.
Headstock bearings should be common. Any bearing house should be able to get them. Pull them out, get the part number, and start calling around. Will probably be cheaper than going back to Powermatic anyway. Just make sure they are "sealed" and not just "shielded". To test the bearings, remove the belt from the spindle and spin the shaft. It should turn smoothly with no noise. If the balls are lumpy, or are audible, they're on their way out. A piece of 1/2" dowel pressed against the bearing housing, and the other pressed on the flappy thing at the door of your ear canal, will give you a good listen to the bearings.
Good luck !
